R60 laptop keyboard removal - Computers & Internet
  • gazg123 Jun 11, 2008
    im sorry for being ambiguous but it is a samsung r60 plus notebook.
    Problem Solver:
  • 9 Answers
Samsung R60 plus laptop keyboard removal
Hi - It's relatively easy!
Remove battery.
Close (but not latch) the lid.
Gently press each hinge cover at the rear of the unit where it meets the base unit (You'll see a joint in the plastic) and get a satisfying click as it lifts. Carefully open the unit almost flat (- careful!) and use a small rounded watchmaker's or preferably similar dimension plastic / wood implement to lift the hinge through the hinge recesses until the switch/indicator plate clicks out at each edge. Then gently use light pressure to remove the rest of the plate away from the keyboard top side. There is a lifting point above the keyboard between the Pause and Insert keys if you need to apply a little extra pressure. There are several moulded clip pieces along the front (keyboard edge of the plate). There are no screws or wired connectors underneath - so lift away. There are two screws underneath the case which hold the keyboard in one either side of the CD/DVD drive locating screw. Turn the machine back over and locate the three plastic lugs in th case at the lower edge of the keyboard. Located near CTRL, Spacebar centre and Down Cursor keys, gently press each one towards the front of the machine with a flat edged implement starting centrally at the same time carefully lifting the keyboard unit. There is a flat ribbon cable connected underneath don't tug it but manouver the keyboard so that you can release it properly.
Job Done!
Replacement is an exact reversal of the removal process - use gentle care and firmly placed pressure to click the various plastic lugs int place.
Now ... about that spilt milk in the keyboard .....!
Posted on Dec 12, 2008
  • 70 Answers
To remove the keyboard, the battery pack and palm rest must be removed before removing the keyboard:
  1. First, remove the battery pack as follows:
    1. Turn the computer off.
    2. Disconnect the AC adapter and all cables from the computer.
    3. Close the computer display and turn the computer over.
    4. Hold the latch in the unlocked position.
    5. Grasp the battery pack and pull it from the rear of the machine.
  2. Next, remove the Palm Rest as follows:
    1. Remove the four screws from the underside of the machine.
    2. Turn the machine over.
    3. Lift the rear edge of the palm rest, then rotate it up and toward the front to clear the tabs along the front edge of the system base.
    4. Carefully lift it high enough to disconnect the TouchPad connector.
  3. Next, remove the keyboard as follows:
    1. Remove the single screw from the underside of the system.
    2. Turn the system over and lift the keyboard starting at the bottom edge then lift it up high enough to disconnect the keyboard cable.
    3. Lift the keyboard out of the machine.
or for better procedure you can check this link for MOVIE procedure.
http://www-307.ibm.com/pc/support/site.wss/
pageRedirect.do/MIGR-66127.html
I hope this procedure will solve your problem.
-mrsolution
Posted on Jun 11, 2008
2 Suggested Answers
SOURCE: samsung r60 plus notebook keyboard removal
Just need to remove the two screws on the rear marked KBD then turn the computer over and unclip the 7 tabs around the keyboard - 3 at the front and 2 either side, then carefully pull the keyboard up and towards you to release it at the back.
-Deo
Posted on Jan 16, 2010
Roberts R60 - Display light on but no display
There is suppose to be a brightness button on your laptop keyboard..Try that
Nov 21, 2016 | Computers & Internet
My Fn key doesn't work
check if ur keyboard is correct plug. And is correct plug. Means you have to get a new keyboard
Dec 18, 2013 | Lenovo ThinkPad R60 Notebook
Lenovo R60 freezes and no response from mouse or keyboard
1) try to RESTORE to some point where the computer was working.
2) Update the BIOS +CHIPSET and RUN it.
2a) see if working. If NOT working go the step #3
3) update the USB driver from the supplier company.
4) updae the driver for keyboard +mouse , uninstall and reinstall.
God bless you
Oct 18, 2012 | IBM Lenovo ThinkPad R60 Notebook
Asus g53 keyboard lights not working
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem. else you have to replace the keyboard.
<a href="http://www.laptopparteshop.com/asus-g53-g51-keyboard-replace.html">Asus G53 Keyboard</a>, <a href="http://www.laptopparteshop.com/asus-eee-pc-1005ha-keyboard-replacement.html">Asus 1005HA Keyboard</a>, <a href=" http://www.laptopparteshop.com/asus-k52-k52j-lcd-cable-replacement.html">Asus K52F lcd cable</a>, <a href=" http://www.laptopparteshop.com/asus-k52-k52j-lcd-cable-replacement.html">Asus K52J lcd cable</a>, <a href=" http://www.laptopparteshop.com/lenovo-g570-g575-lcd-hinges-replacement.html">Lenovo g570 hinge</a>, <a href=" http://www.laptopparteshop.com/ibm-lenovo-b570-g570-v570-z570-keyboard-repalce.html">Lenovo g570 keyboard</a>, <a href=" http://www.laptopparteshop.com/ibm-lenovo-g550-keyboard-replace.html">Lenovo G550 keyboard</a>, <a href=" http://www.laptopparteshop.com/sony-vaio-vgn-ns101el-keyboard-replace.html">Sony Vaio VGN NS101EL keyboard</a>, <a href=" http://www.laptopparteshop.com/sony-vaio-vgn-ns101el-keyboard-replace.html">Sony Vaio VGN NS101EL keyboard</a>, <a href=" http://www.laptopparteshop.com/hp-g42-laptop-cpu-fan-replace.html">HP G42 fan</a>, <a href=" http://www.laptopparteshop.com/hp-g62-laptop-cpu-fan-replace.html">HP G62 fan</a>, <a href=" http://www.laptopparteshop.com/hp-g62-233nr-234dx-cpu-fan-replacement.html">HP G62-233NR fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV52 fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV78 fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV56 fan</a>, <a href=" http://www.laptopparteshop.com/lenovo-a600-cpu-fan-replacement.html">Lenovo A600 fan</a>, <a href=" http://www.laptopparteshop.com/samsung-r60-r70-keyboard-replacement.html">Samsung R60 Keyboard</a>, <a href=" http://www.laptopparteshop.com/samsung-r60-r70-keyboard-replacement.html">Samsung R70 Keyboard</a>, <a href=" http://www.laptopparteshop.com/toshiba-t135-t135d-keyboard-replacement.html">Toshiba Satellite T135D Keyboard</a>, <a href=" http://www.laptopparteshop.com/toshiba-satellite-e205-keyboard-replacement.html">Toshiba Satellite E205 Keyboard</a>
Oct 03, 2011 | ASUS G73JW-A1 Notebook
Where is the cmos battery located on the samsung r60 plus
Glad to HELP YOU!
As a rule of thumb: for laptops/notebooks/netbooks the CMOS battery is located under the keyboard. So you have to remove the keyboard in order to reach the CMOS battery.
Here I've found for you a nice video that will show you everything in detail.
GOOD LUCK!
Mar 17, 2011 | Samsung R65 Notebook
Oh my laptop IBM R60 bios password and try by removing cmos battery but still please email me if u got the ideal
Removing the BIOS battery did not reset the BIOS password because the BIOS password is stored on an EEPROM chip. visit laptopmasterpassword.net
Sep 24, 2010 | IBM ThinkPad R60 Notebook
Samsung r60 plus - wireless become disabled
Have a look around the edges of your lapto pto try and find a wireless switch, if its not there then it may be on your keyboard usually you have to press FN then another key to enable it. if its not this them it could be turned off in the BIOS or you may have a corrupt driver. Cant direct you to the exact location of the switch it will be there just have a real good search around and on the keyboard . Hope this helps
Dec 02, 2009 | Computers & Internet
Samsung r60 plus notebook keyboard removal
-Deo
Jun 11, 2008 | Computers & Internet
Computers & Internet Logo
3,710 people viewed this question
David Payne
David Payne
