Question about Kenmore 43142 Front Load Washer
Kenmore he2 will not drain and spin - Kenmore 43142 Front Load Washer
  • 246 Answers
Most likely is a clogged pump. Remove the 2 1/4 inch screws on the front, botom panel. There is a white peice of plastic in the botom front slightly off to the right side. This is your pump. Slowly turn the knob in the center counter clockwise while you have a bowl of bucket under the lip of it. Once you have bailed the water out of it, unscrew the knob all of the way and pull it out. Check the pump and remove forign objects.
Posted on Jun 15, 2008
Great fix
Posted on Jul 14, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
My he2 kenmore clothes washer does not go into spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
My Kenmore He2 at the end of wash my clothes are still heavy with water and a f01 code is flashing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
My kenmore front loader does not go into the spin cyclr and water is left in the drum
Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
Our kenmore he2 won't drain/spin out
drain pump checked out good...still won't drain
Jun 28, 2009 | Kenmore HE2 Plus Front Load Washer
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Does anyone know the code to make a HE2 Plus "spin only"?
select the Spin/Drain cycle. any special code would have been the service/diagnostic mode but that wants to run a factory test which involves water fill and agitate
Apr 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 43142 Front Load Washer Logo
168 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
