Question about Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 9 months old
My garmin has developed several intermittant problems.
It sometimes cannot acquire sattelites even when outdoors on major highways. Sometimes the speech is halting and unintelligible.
    Scholar:
  • 174 Answers
Have you ever tried updating the firmware with garmins webupdater?
Have you had this issue with a fully charged battery.
Do you hear anything rattle in the device when you shake it....I had a spIII color with similar issues, found out that one of the circuit board mounting screws was travelling around in the case.
If this is the case, and you are tech savvy you could open the GPS and probably find the culprit. If not ship it back to Garmin, for it is still under warranty.
Posted on Jun 12, 2008
My garmin 350nuvi will not acquire sattelites
Make sure to flip your antenna horizontally or 90 degrees and not vertically or 180 dgrees. I see to many people try to use their older nuvi this way and it does not function well.
Try also updating your unit with the latest firmware from Garmin, this helps sometimes.
You may have moved to a location that is far away from the last location your Garmin nuvi 350 was last use, try to keep your unit on for 30 minutes or more to see if it will acquire GPS sattelites.
Last, certain vehicles have shielded windshields and GPS does not work well with these windshield, this can be eaisly verify by simply taking your nuvi 350 out of your vehicle and turn it on with a clear view to the sky, if that still does not work, it could be a defective GPS receiver or GPS connection in which case you should consider sending it in to Auto Nav 2000 Plus, Inc in San Jose CA or Garmin.
You may also consider replacing your nuvi 350 with a newer model nuvi with fresher map.
Good luck
Apr 03, 2010 | Garmin Nuvi 350 Car GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
Garin nuvi 200 cannot aqcuire sattelite
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 Can not locate Sattelites
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 21, 2008 | Garmin Nuvi 660 GPS Receiver
Is not able to access the satellite
Update your unit. Garmin has this problem where you try to enter a location before it acquires satellites. It is very noticeable on the Garmin Nuvi 650 also. Another thing you can try is wait for it to acquire the satellite and see if you don't get up and running. In some cases, it can take up to 4 minutes to acquire satellite information. If this is also your case, updating the firmware to 6.10 should fix that also.
To find what your firmware version you have, click on the TOOLS icon (wrench), click on SYSTEM, ABOUT (bottom of your screen). Anything less than 6.1, you'll have issues.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Gps starts in kansas city when turned on
Read the phamplet, page 3, acquiring a sattelite
Jun 16, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 GPS will not find sattelite
I GARMIN KEEPS SAY MEMORY IS FULL HOW DO DELETE IT
Feb 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Dec 07, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
51 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
