Question about Palm Treo 700p Smartphone
Treo 700P Charging issues
The other day out of the blue my Treo 700P would not accept a charge. I wiggled the wire a little and the red light would come one for a second. Now I have it charging, but it's been charging for almost 7 hours and it's only at 60%. Earlier when I checked on it, it said 84%. I haven't unplugged it. Is it more likely the connection or the battery? Thanks in advance!
I'm assuming you have problems with syncying also. What I do is turn off the Treo, take out the battery, and unplug the the cord from the USB port. With everything unconnected clean the contacts in the treo, on the outside of the treo and the plug on the chord with alcohol on a Q tip. On the battery only clean with a dry cloth, no alcohol.
Put it all back together and see if you get a better connection. If this doesn't work it is probably your battery.
Posted on Jun 27, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 848 Answers
Treo 700P Charging issues? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 190DTLA A2H PI 190DTLA PI 170DTLA 200 000 170DTLAH V7 860 AB0...
Posted on Jan 08, 2015
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
My treo pro wont charge the battery. I have purchased a new battery but the problem persists. I connect the phone to its craddle and tha charging indicator turns on; however, the battery remains at...
Either the charger port on the phone is faulty or the charger itself. Try a different charger if you can and if this works, the dock is faulty, if it doesn't then its the phone. Pretty simple repair and most Treo repair centres will be able to do it.
Feb 03, 2011 | Palm Treo Pro Smartphone
WHEN I CHARGE MY TREO 650 THE RED LIGHT AND CHARG...
Charging circuit cause trouble due to heat, please see a technician or first use "restore factory settings"
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Palm Treo 650 Handheld
My Treo 700p won't turn on. Even with battery fully charged. How do I reset it?
there is a hard reset button under the battery cover on the side where the stylus goes. it should be able to restart your device fully and completely, is some cases you may need to leave the battery in and charging for at least a day or even use a friend's battery , because some glitch certain devices just refuse to boot and also to charge the battery if they somehow recognize the battery then in my case I use my wife's treo battery to be able to get mine jumpstarted. whenever I experienced this after a while I was able to switch back to the original battery and then the device was finally charging that one. weird but true, so we switched to android based devices since. but I remember this issue clearly.
Jan 13, 2010 | Palm Treo 700p Smartphone
Treo 700 P red, white, blue, green checkered screen
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Jul 28, 2009 | Palm Treo 700p Smartphone
Error 0.14
Nov 18, 2008 | Palm Treo 700p Smartphone
My Palm Treo 500 is not charging correctly!!
If you have had this phone for a long time its probably your battery.
Oct 08, 2008 | Palm Treo 500 Centro
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Palm treo 700 wx won't charge
Verizon 700wx:I had the same problem. With little or no movement, the phone would go from charging to not over and over. At home with it perfectly still it would charge maybe 1/4 in 6 hours. Same problem with 3 different chargers. With the battery out, I dipped a Q-tip in rubbing alcohol squeeze out excess and jammed it into the charging port on the phone. Put the battery back in and oh **** nothing. Took it back out and let it dry for a few minutes and were back in business. No more charging problems at all.
May be a little risky, but warranty was up and what did I have to lose. Anyway good luck!
Feb 16, 2008 | Palm Treo 650 Handheld
My treo 700w phone is off
hold the red power button down for 2 sec then it should say welcome if not then take the battery cover off and to the left of the battery is a reset button you can press with the sylus
Jan 03, 2008 | Palm Treo 700w Smartphone
Palm Treo 700p Smartphone Logo
136 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
