My right speaker channel (Front Speaker) is going bad - the audio is there but it's breaking up and has a static-type sound. I swapped speakers, speaker wires, changed selection from Speaker A to Speaker B, and I get the same result from either TV, radio, or CD player.
Thanks for your help!
John
SOURCE: Left channel out
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
SOURCE: both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
SOURCE: str-gx800es sony receiver problem- right
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Sony STR-GA7ES
