Question about Riso RZ220 Duplicator
Riso Rz 220
I keep getting two codes when trying to make a master. A16-525 and A34-218. I clear the error and the machine tries to continue and produces the other error. The master is not transfering to the drum. It seems, also, that the machine is stuck in print mode an not in master making mode. I cannot reset the machine.
  • 1 more comment
  • Anonymous Mar 13, 2014
    when i start for master copying,it wil not continue,and an error code P01-537 coming up,when i reset it the problem again,
  • Anonymous Mar 17, 2014
    the master roll is not getting to the drum
  • Anonymous Mar 18, 2014
    Master-disposal jam sensor was OFF at both 120 and 180 degrees drum angle
    New Friend:
  • 34 Answers
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Posted on Jul 30, 2008
    New Friend:
The product copy is not clear even I tried to make it many times.How to it in order to have a clear copy?
Posted on Jul 30, 2013
  • Neenya Sep 09, 2013
    Riso RZ 220 UI check setting light on. Master drum will not release. Green light not on. Flim will not load. #4 light is on
    New Friend:
Try to power OFF the machine then hold reset key then power ON the machine while you hold the reset key. The machine will work again without error.
Posted on Mar 01, 2013
Try to clean the master sensor . if not worked replace it
my best wishes
Posted on Jun 13, 2008
Riso RZ 220 UI The master drum will not come out and the green light is not on.
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
Sep 09, 2013 | Riso RZ390 Duplicator
Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Feb 22, 2013 | Riso RZ220 Duplicator
Riso rz 220 the code A17 209 continues to come up
Hello
Yor cutter unit is not in the home position.
Open the front door, take out the master unit, remove the master material, lift the green handle and look to see if you can see a white plastic knob (that is the cutter) make sure it is to the front of the machine, if its to the back of the machine very carefully move it forward until it wont move anymore.
If it is in the front of the machine then the microswitch is probabally faulty and will have to replace the cutter unit.
Regards
May 18, 2011 | Riso RZ220 Duplicator
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
F0115 riso rz-220
The code means there is no master on the print drum.
Jan 19, 2010 | Riso RZ220 Duplicator
Error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Nov 30, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Machine error Riso RZ 37 EP
Make sure you have taken all the master out the dispsal box, also make sure the senser is clean and there is no pieces of master stuck around the wheels inside the unit.
Nov 17, 2008 | Riso RZ220 Duplicator
2,020 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
