Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf 250 aquaries
Do u KNOW HOW U RESET YOUR PROGRAMME ON THIS WASHER AS PREWASH KEEPS COMING ON NO MATTER WHAT I DO AND IT KEEPS ON WASHING AS LONG AS I LEAVE THE WASHER ON I TRIED PRESSING THE CANCEL BUTTON BUT THIS HAS NOT WORKED I HAVE ALSO TRIED UNPLUGGING IT AND THIS HAS NOT WORKED THANKS
  • 66 Answers
Try changing your water valve this should sort problem
Posted on Jun 15, 2008
Hotpoint wf250 .start wash ,door lock light comes on ,wash light comes on,door lock light gose off.wash light stays on.can hear the cold valve clickbut fails to fill.dose not start cicle
Posted on Dec 27, 2009
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquaris washer/dryer. no heat when on drying programme.
needs new stats or elaments or the j19 on the module has burn out
Mar 26, 2010 | Washing Machines
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD129 Wash programme stuck
i am having the same problem with my widl126 washer.
ant help?
Apr 30, 2008 | Washing Machines
HOTPOINT aquarious extra
try putting the drain lower worked on our WF 541
Dec 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
474 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
