Restoring back up files
Have had to do a system recovery on my pc.
It backup all my files that I was using and am now trying to access them and restore them. Is this possible?
I can see the files that I need on my computer, but can't access them.
This includes my printers, scanners, web acclerator program and pictures.
  • 1,447 Answers
Hi check this link: Microsoftrestore
Posted on Jun 11, 2008
Computer won't start. Message keeps saying " attempting to restore Windows" but seems to be in a loop. What can I do
I hope this will help
Method 1. Reset your Windows 10 PC
Navigate Start > Settings > Update and Security > Recovery > Reset this PC.
Then Hit on the Get Started button just below the option to fix Windows 10 'Restoring your previous version of windows' stuck issue. During the process, select Keep my files option will allows you to keep all your personal data safe.
Method 2. Perform a System Restore or Startup Repair
1. Download Windows 10 media creation tool and create a Windows 10 installation media.
2. Boot or start your computer from the Windows 10 installation media.
2. In the Install Windows page, tap 'Repair your computer' to start the Windows Recovery Environment.
3. In the Windows Recovery Environment, on the Choose an option screen, click 'Troubleshoot'.
4. Click 'Advanced Options' and then click on 'System Restore' or 'Startup Repair'.
Then follow the on-screen instructions to fix Windows 10 'Restoring your previous version of windows' stuck or loop and restore the computer to an earlier state successfully.
Method 3. Clean install Windows 10 with ISO image
If none of the above methods is helpful, you can try to reinstall Windows 10 with ISO image file. Just download Windows 10 media creation tool. Try it to download Windows 10 ISO image file and burned it to bootable DVD or USB flash drive. And then clean install Windows 10 on your PC. It has helped most users to fix Windows 10 stuck at 'Restoring your previous version of windows' loop.
Method 4. Restore Windows 10 using previous backup image
The above methods are all the possible free solutions from Windows 10 settings to fix Windows 10 stuck at 'Restoring your previous version of windows' loop. Actually, at most times, they might not help due to certain reasons. So we strongly recommend you to backup Windows 10 system with EaseUS Windows backup software. It can help you easily and quickly restore your system from the backup image without losing anything when a disaster happens unexpectedly.
Feb 08, 2018 | Computers & Internet
Restore recovery disk
Hi Billy,
depends on what you mean by restore. Assuming you have windows installed, you can make a back-up by going to START > Control Panel > System and Security > Create a backup
(the path above may be a bit off from the wording, the PC I am on at the moment is not an english version.)
Then on the left side there is a link to create a recovery disk or create a backup. the recovery disk option only makes a bootable disk to start your computer if your windows cannot start. This only gives you an enviroment where you can try to fix windows or to restore a backup that you created beforehand with the second option above.
If you create a backup, there are two things to keep in mind... what type of data do you want to back up and how often. You can put check marks on all data that you want to backup (Note: the more data you backup the larger your backup file will be). If you plan on restoring a corrupt windows with the backup you should include "System State".
Restoring from a backup file a.k.a. backup image will ONLY give you back the files that were on your computer at the time you made the backup... that means everything that you created after you made the backup will be lost.
Hope that helps.
May 16, 2014 | Dell XPS 200 PC Desktop
Location of backup switch
Every time you sync your iPhone with iTunes, if the auto-sync option is on, iTunes will create a backup for you. And the backup is saved on your computer. According to different OS, the location is different. Learn specific information about where is the iTunes backup located - location of iTunes backup.
Aug 01, 2013 | 1993 Toyota Camry V6
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
Hi, I accidentally deleted my back up file in the back up manager. is there a way I can retrieve it? like restoring it from a "recycle bin" of the back up manager? one more thing, I just bought a SE...
Since this is a propratory backup system it may be difficult to retrive the deleted backup. However, there are third party application you can to try the recovery of the deleted backuped files. Try Get Data back recovery software or file Scavenger software. I know you can export your contacts to your mail (for example outlook) and syn it back to your new SE Naite.
Sep 25, 2010 | Computers & Internet
Restoring files after using the Backup utility.
1. Plug in the USB drive that contains the data.
2. On the XMB go to Settings then System Settings
3. Go to Back Up Utility like before but
4. Choose Restore rather than Back Up
5. The PS3 does the rest
You can have the PS3 delete the data file from the USB drive by choosing Delete Backup Data.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
Restoring 52 gb .fbw ext file on window vista
Use Emergency Recovery Tool from SoftThinks this will recover all the files backed up in your .fbw file
May 04, 2009 | Microsoft MediaRecover File Recovery...
I had to do a system recovery disk on my computer and I would like to know if ANY of my pics or files can be restored in my computer??? I have resumes in there and my daughter's portfolio somewere
If you did a system recovery from the disk it most likely has reformatted your hard drive. The only way to get the files back is if you had made a backup before restoring.
Jan 02, 2009 | Computers & Internet
Restoring files from the database
I suggest you use the Enterprise manager (gui tool to manage SQL).
Restoring a single table is not an option.
You can however restore a file or filegroup.
Make sure to backup before you start and NOT to restore database to its original name or original file location, to avoid acidents.
Normally you will have databases with only 2 files: the data at its Primary file group, and log file.
You may wish to create a new file group and move tables to the new group by recreating them there and exporting data from old table to new table. Then recreate indexes. This may prove to be complex as all tables and indexes have unique names and can't coexist with exact duplicate of them.
oh yea..... did I say backup?
well just in case backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup
but dont overwrite that backup
Feb 11, 2008 | Microsoft SQL Server 2000 Standard Edition...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
