Question about Amana PTH123B25AJ Heat Pump Air Conditioner
2 problems.. AC Comp cuts out. And Fan will not stop.
I have amana PTAC's (Amana PTC094B35AE) installed in my hotel and am having issues with 2 units.
1) When you cut on the AC the compressor kicks on then kicks out after 2 minutes.
2) The second one the AC is not working at all. However, the fan runs constantly. The fan runs with the master switch in the off position. The only way to stop the fan is to pull the main fuse for the unit.
  • Jim HGI Eng Jun 12, 2008
    Thanks! I got the same advise from an HVAC tech on #1. I've gotta pull the unit to clean the coils good. I'll let you know if that fixes it.
    jim
  • stanita12 Jul 11, 2008
    I have an Amana PTAC Model # PTH153B35AE. The a/c was working then all of a sudden no air. I turned the AC off then back on, I can hear the compressor trying to come on, but then the system shuts right down. I cleaned the filter and coil but I still get the same thing.
    Scholar:
  • 54 Answers
Unit#2 -Sounds like the contacts on the master switch are welded closed or the switch is broken, Replacing the switch should fix this unit.
#1 is a little more difficult to diagnose. The compressor is being taken off line by a circuit that protects the compressor from damage either; 1- liquid refrigerant getting back to the compressor which can be caused by something as simple as a clogged return air filter or evaporator coil on a heat pump or 2- overload situation caused by a bad condenser motor or a clogged condenser coil. The first thing you need to do is clean both coils and replace the filter,. Then check to be sure your getting good airflow across both coils. I think it's most likely an airflow issue I hope this resolves the problem GL!
Posted on Jun 12, 2008
    Problem Solver:
  • 11 Answers
These unit runs on 240 volt, make sure the outlet is not 110 volt, that would trip the breaker.
Posted on Jun 27, 2012
    Problem Solver:
  • 6 Answers
I can assist and supply parts to help you refurbish your ptacs. call me at 1-888-855-9987
-bob
Posted on Sep 09, 2008
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
Amana ptac error code C7
It's most likely your thermostat the one up front that plugs in under your control panel. Had one do the same thing replaced it now works perfect.
Mar 25, 2013 | Heating & Cooling
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a new Amana PTH15E PTAC. When heat is used, sometimes is quite but sometimes sounds loud (like window AC), why?
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Jan 02, 2011 | Amana PTH123B25AJ Heat Pump Air...
I HAVE AMANA A/C.MODEL PTC135A25AC WE HAVE PROBLEMS WHEN INSTALL NEW BOARDS THE NEW BOARDS HAVE ONE BUTTOM ON THE CENTER AND HEAT,COOL,OFF ON THE OTHER SIDE THE PROBLEM WITH THIS BOARDS WHEN PUSH FOR COOL...
When you change the board on an Amana youmusty program the board. You should have gotten a sheet that shows you how to do this. I sell Amana PTAC units and all boards have to be programed for heat pump or electric heat.Russ
Jul 28, 2009 | Heating & Cooling
Wiring for an Amana PTL
That is a stinger leg and you will burn the unit up. 2-@110/ground is what you need.
May 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Ptac not heating
the board or the heater need to be replaced
Dec 23, 2008 | Amana AAC051FRB Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
728 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
