Question about Sewing Machines
Necchi Logica bobbin case
The tab on my Necchi Logica bobbin case seems to be holding the bobbin too tight causing the bobbin to bind and jam.
  • Anonymous Aug 24, 2008
    I have a logica sewing machine with similar problems when start the machine to sewing the bobin is hold due the wire is around in less than five strokes.
  • Mary Dunn Aug 04, 2010
    Can you please write your problem so we can understand? It does not make any sense what you have written. No one can help, if, you aren't clear
bbtoast
  • 319 Answers
SOURCE: bobbin case
Please see the authorized instruction manual here. Page 57 and 58 relate to your problem. If you need further help, please reply with updates!
Thanks
Posted on Feb 17, 2008
ahamed100
  • 148 Answers
SOURCE: Bobbin case.......
A bobbin case for accommodating a bobbin which has a shaft portion and a collar portion formed on both sides of the shaft portion on which a thread is wound, the bobbin case comprises: an opening being opened on at least one side of an axial direction of the shaft portion, for detachably accommodating the bobbin; a thread take-up portion provided in the axial direction opposite to the opening, for pulling out the thread of the bobbin; and a holding member which makes contact with the bobbin and nonrotatably holds the bobbin.
Posted on Mar 04, 2008
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
What size is the bobbin to a vintage Necchi Supernova? Any replacement??
NO. IF IT IS TOO TALL IT WILL CAUSE A PROBLEM. GO TO THE LOCAL SEWING MACHINE SALES AND ASK IF THEY HAVE THE RIGHT ONE. ALSO, YOU CAN TAKE OUT THE BOBBIN CASE (HOLDS THE BOBBIN) AND TAKE IT WITH YOU. MAKE SURE IT DOESN'T EXCEED THE HEIGHT OF THE CASE AND IT SHOULD SPIN FREELY.
Sep 18, 2017 | Necchi Sewing Machines
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Oct 20, 2016 | Necchi Sewing Machines
I have a Necchi 575FA and the bobbin thread cloggs up.
try changing the needle
also try using a different bobbin just incase there is something
wrong with that one
make sure the thread is wound evenly on the bobbin or this will
cause problems
make sure the bobbin is turned the right way in the bobbin case
Nov 29, 2012 | Necchi Sewing Machines
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
Why does the shuttle hook grab the spool thread instead of the bobbin thread? It wraps the thread around the bobbin and binds the machine up.
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
~<Ray>~
Nov 13, 2010 | Necchi Sewing Machines
Handwheel Stuck
How about the belt? you have to take off the outer case, usually a few screws and check it. Also, when you have the case off, look for thread inside.
Jul 24, 2010 | Necchi 3610 Sewing Machine
Unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Nov 18, 2009 | Singer Sewing Machines
Bobbin case on my 524fb necchi has come apart
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
May 01, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
90 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
