Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
" WD Sync could not save your data"
I tried to open up a file but the messaqe " WD Sync could not save your data" keeps popping up. I just opened up the file last week and it was fine. How can I retrieve the information again? At some point the file was saved so I don't understand how it disappeared. It is an excel spreadsheet.
    Genius:
  • 3,422 Answers
Please CLICK HERE and check out the link.It will help you fix this issue.
If you need anymore help let me know.
Goodluck,
Please don't forget to rate the solution
Posted on Jun 11, 2008
    Master:
  • 638 Answers
Try doing the same procedure remove it slowly and slowly reinsert properly and then see.
  • hemant somaiya
    hemant somaiya Jun 11, 2008
    this link have total information about your problem just click and solve all the problems in minutes
    http://www.dmailer.com/site/support/faq_...
    if this solution helps u please rate it as fixya to encourage us to solve more and more problems. thank u for using fixya. good luck.
  • hemant somaiya
    hemant somaiya Jun 12, 2008
    is ur problem solved or u need more help.if solved rate my solution as fixya
    Genius:
  • 1,447 Answers
Hi-
You can actually try to reopen file when you click on File "open", then look for recent documents, then open the file if you can find it on the list, one other thing is to restore computer from the date you can actually open the file, but if you have a backup file for it, then restoring will be the last option.
Keep me posted if you need more assistance. Have a nice day!!
    Genius:
  • 1,665 Answers
Corrupt excel 2010 file
1 - Using "Open and repair"
Microsoft Excel has a built-in repair tool for corrupted files. To access it, go to File and Open. A menu will pop up in which you'll have to select the file you want to fix and then choose "Open and repair" from the dropdown menu. This will open a dialogue box in which you can pick between the repair option (which will recover as much information as possible) and the extract option (that will copy values and formulas). The two alternatives combined should work fine to save your work.
2 - Saving the file to a different format
If you can open the file but you can't modify it or save the changes, you should use this method. You'll have to save the file to a different format (such as SYLK or HTML) via the "Save as" menu. Once you've done this, you'll have to open the recently saved file and then save it once again (but this time, you'll have to choose the Excel Workbook as the format). By doing this, you'll be creating a fresh new file with all the data from the corrupted file.
3 - Opening the file in Microsoft Word
This option is only available for the people that have the Microsoft Excel converter installed on their PC (it can be downloaded from the Microsoft website). You simply have to open the corrupted Excel file with Word. However, you should know that this method only works for retrieving data (all the structures from the sheet will be gone, such as formulas and macros).
4 - Altering the Calculation option
If your file isn't opening at all you can try to adjust the calculation option. Simply open Excel in a blank workbook, go to the "Tools" menu and look for "Options". There you'll find the "Calculation" tab in which you'll have to look for the "Calculation" section and set it to "Manual". Click OK and then try to open the corrupted file once again.
5 - Linking the corrupted file
In this method, you'll have to link one cell of a blank worksheet to the corrupted workbook. Be sure to create the new worksheet in the same location as the corrupted file. Once you've done this go to the blank worksheet and enter the following in the A1 cell: <Filename>!A1. This will copy the data from the A1 cell of the corrupted file to the new sheet. In case it works, simply click "Edit" on the cell and select an area like the one covers the cell that contain data in the damaged file, and then click Paste. Then (and with the cells still selected) click Copy on the Edit menu.
Jan 23, 2013 | Western Digital Corporation WD ShareSpace...
I was just using my 500GB WD Passport Essentials to store data I had in my PC. Everything was going fine. I was cutting from the PC and pasting to the WD. Suddenly, when I tried to paste one of the files,...
It's hard to say from your description what the problem is but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if that does not work you will need data recovery help. A good choice for low cost and fast data recovery is http://FreeDataRecovery.us
They do data recovery remotely over the Internet from a boot cd that you download and the best part is they just ask you to make a donation after they recover your data.
Sep 22, 2011 | Computers & Internet
Error msg
try to format the drive
Feb 25, 2010 | Western Digital Computers & Internet
When I tried to open act version 2006 it would not open the current data base and it directed me to an earlier saved file which I mistakenly loaded, by doing so I "lost" 350 contacts from an 10 month...
The database may be corrupt or on a network drive not accessible at the time you tried.
Open ACT. Go to File/Open Database.. Look for all files ending in ".ADF" files where you suspect them to be, then try opening them. One of them is most likely your data file. If you use the "DETAILS" view, you can see the last date the file was accessed and this too should help you define which file you want.
Don't worry by opening a new file you did not loose any contacts or data.
Once you get them back......back them up for safe keeping.
Good Luck
Dec 15, 2009 | Sage ACT! 2006 Upgrade Version (License...
Cannot open file due to I/O device error!!!
dont worry, you can recover files from WD external hard drive, you need to follow the correct steps, here's a perfect data recovery tutorial for you
Recover files from External Hard drive
The tutorial is very easy to follow as I followed it to get back my files.
Apr 06, 2009 | Western Digital Passport 160GB External...
Cannot save my data
1.open a second instance of Spss
(do not open it by clicking on a saved file -it will not open the backend that is requierd to let you save)
2. Make a new blank data file
3. go back to your original non-saveable work -- highlight the top tabs (and all your work) right click and hit copy.
4. go to the new blank spss data - right click on the top tab and hit paste- viola your work is now in a saveable version of spss (save now!!!!)
This problem occurs when the program is opened via a saved spss file and it does not open the second part of the program that allows you to save (bad bug). it is in view mode and will let you enter many hours of data before you release you cant save. (My wife was crying when she didnt think she could save her project for Grad school she had been workin on for 19 hours) I got lucky and figured out this work around.. Hope this helps all future SPSS folks this was a workaround for up to spss 17 (dont know if it works for 18 or if they have fixed this glitch).
Search SCA Gulfwars on facebook and say hey on my wall if this helped Ya..... Good Luck
Apr 01, 2009 | SPSS 13.0 (30960UU)
I don't know how to check the files on my WD passport. I'm looking just for pictures and itunes. Can you tell me how this is done?
you plug the drive into a usb port.... if it doesn't automatically pop up to allow you to access the drive... go to my computer (or computer on vista) and go in there... it should appear as another drive. double click and you are in the drive.
Robert
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Recover western digital passport "sync-data"
You need to have the WD Sync program on your computer; you can get it from your WD Passport, or, over the Internet. Once you have the software on your computer, you can synchronize. WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a
backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a
computer to the drive (WD Passport) and SHOULD NOT be used as backup
software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as
this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the
WD Sync software, reformatting, and using the WC Passport as a true backup
drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
Dec 24, 2008 | Western Digital Passport WDXML800UE...
TANSFER DATA from SONY CLIE SJ22 to HTC TYTN2
I'm in the process of changing from SJ22 to Smartphone running Windows Mobile 6.1 and I have found a way round this by sending data as vcard to myself in outlook then opening the attachment and saving and closing - this is then sent to your device on the next sync. It is a bit long winded but it works.
Open Outlook and leave it open.
In Palm, select the address you want to send, then in EDIT menu choose Forward as vcard, send and close the outlook pop up, saving changes.
Go to Outlook Inbox and open the attachment then save and close.
Aug 11, 2008 | Sony CLIE PEG-SJ22 Handheld
Memory stick problems
fush, the same **** happens to, dude
Apr 05, 2008 | Sony PlayStation Portable (PSP) Console
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
701 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
