Question about HP LaserJet 4050tn Printer
Engine Test Printer was working very well and then for no reason started printinng 1/4 inch space lines on every page until both paper trays were emptied. (Landscape). During this printing frenzy the display showed: Engine Test I turned off the printer for about 5 minutes and when I turned it back on the display showed: Ready, until I tried printing & then it went to Engine Test again & started to empty the trays. I know it's an "old" printer and I just need to know if I need to set it out with the trash.
  • 35 Answers
Replace engine control brd.
C4118-69009 Is the part #
you can get it from a company in FORT LAUDERDALE ,FL
CALLED COMPUTER AND PRINTER SOLUTIONS.
PHONE #1-866-946-3692
ASK FOR RENEE SHE IS THE PERSON I 'VE BEEN DEALING WITH FOR YEARS.
SHE HAS SOME VERY GOOD PRICES.
SHE TAKES SOME PARTS SUCH AS FUSERS,BOARDS IN ON EXCHANGE WHICH SAVES MONEY.
Posted on Jun 12, 2008
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
How do you eliminate a line going through each page
Run a 1/2 print test.
Put paper in the manual feed tray (tray 1).
Print something. When the paper feeds 1/2 way into the printer, open the top cover.
Remove the toner cartridge and look down at the paper. If you see the line, replace the toner.
If there is no line, then the problem is probably the fuser.
Feb 13, 2011 | HP Laserjet P3015X Printer
My Brother HL-2140 Laser Printer prints horizontal lines (about 1/8-inch long) at right hand edge of paper. They are spaced at about 2.5 inches apart down the page. Help!
It is most likely that your Laser Unit is failing. It could also be dirt on the electrodes of the drum unit and machine body or the ground terminal on the paper tray is bent. It is best that you visit you local Brother Authorized Service Center for additional help.
Thank you for using FixYa! - Don't forget to rate our service!
Feb 07, 2010 | Brother HL 2140 Laser Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
Feb 23, 2009 | HP LaserJet 1320n Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
OKIpage 10i does not accept A4, and wants 'Letter'
Maybe you won't be able to use A4 paper, which I think is 3/4 inch longer than letter-size 8 1/2 x 11, according to the sizing inside the paper tray of my OKIPAGE 10e. My computer, using Windows 98, doesn't list OKIPAGE 10e among the printers I can use with my computer. Yet, Windows 98 has incorrectly identified my printer as Okidata OL-600e for some reason. I'm surprised my printer works at all with Windows 98. Thanks for detailing your question as "when I print a test page (from the printer controls), because I was unaware I could print a test page using printer controls, so I started pressing anything that looked like an electronic button on the top of my printer. I believe this trial and error eventually helped me to get rid of an unwanted 1 inch wide bar, from top to bottom of 8 1/2 x 11 pages about 2 inches from the right-hand-side of my pages. This was progressively getting worse. I thought I was going to have to buy a new printer. I bought this printer used, and without instruction booklet, so I used your info. about printer controls and started pressing electronic buttons. It's amazing, because after I made about 35 copies, now the annoying 1 inch wide black bar is gone!
Feb 12, 2007 | OKIPAGE 10i Led Printer
Open Questions:
HP LaserJet 4050tn Printer Logo
54 people viewed this question
Ben Johnson
