Question about HP Pavilion dv6000z Notebook
HP dv2000 series
My laptop currently shows that power is on, but the monitor will not show anything at all it is just a blank screen at all times.
  • 114 Answers
Dead Processor or RAM is dead, Bring it to your local PC shop and have them take a look at it.
Posted on Jun 11, 2008
My laptop screen is not coming on it is receiving power but still not coming on
Timothy, post the laptop manufacturer, and the laptop's model number. It's on the bottom of the laptop, Usually in a sticker, or white Service Tag.
This way I can guide you in more detail. Post back in a Comment.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector, on the laptop.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Could be on one of the sides of the laptop, or the back of the laptop.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor, that has a VGA cable attached.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least three display options available:
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
Which one is it? Dunno. You didn't state what laptop manufacturer, and model number.
It is one of the F1 through F12 keys. Most of the time the F4, or F5, or F7 key. Has a monitor symbol on it, and sometimes a side arrow.
No display on external monitor still?
Hold the Fn key down again, and at the same time tap once more on the Display Toggle-Over key.
If the display still does not show on the external VGA monitor, you have a bad graphics chipset on the motherboard. Usually means motherboard replacement.
(There are problems with HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series, in this area. There are other model series of laptops also, not just HP. There is a solution besides motherboard replacement)
C) IF, the display shows on the external VGA monitor, you have a problem with the Video Cable, or inside the Display Assembly.
I can help you find it, just need the laptop manufacturer name, and Model Number.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
My computer won't start. when switch on it beep once and power comes but blank screen and stay that way, nothing happens. pls help thanks
Hmmm.. are u using an LCD monitor?
Did u try to use another monitor?
Even on start up, the BiOS didn't show up?
Tell me more...
Dec 03, 2010 | HP Pavilion dv2000 Series Laptop Full...
What are the appropriate steps to connect an external monitor to an HP Pavillion DV2000? When I try, nothing appears on the external screen... Thanks, RF
One of the function keys has a small monitor screen icon. Press that key while holding the Fn key, and you will enable the external monitor connector. These laptops don't automatically sense when you've connected an external monitor. On some models, the first press enables the external monitor and shuts off the laptop screen. If that happens, press the keys again and the laptop screen will come back on.
Oct 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Display freeze then colors became crazy
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP pavilion Entertainment laptop and recently the screen went blank while the power was still on. I restarted and the screen continued to stay blank. I then turned the laptop off and unplugged it...
The connecting data bus between ur laptop monitor and ur motherboard has either been at fault or else there has been some problem with the wire connection between the two......i.e it has been loosen up....
Get ur laptop checked from the hp representative and if possible get ur laptop insured under different laptop policy schemes.....
With Regards
Abhineet Raj
Jul 29, 2009 | HP Pavilion dv2000 Series Laptop Full...
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
HP DV2000 screen going blank when try to restart my laptop
Check the swapping monitor function screen FN + F4 on Compaq.
It allows to change from internal to external or Both monitors.OR
Start in Safe mode with VGA basic settings and configure your Display settings.
Dec 14, 2008 | HP Pavilion dv6000z Notebook
Compaq monitor blank screen
If its a blank screen all the time that never shows anything not even a screen at startup then it sounds like the internal cable from your monitor to the motherboard of the laptop is unplugged or possibly broken. You need to remove the keyboard from the laptop to check this.
I recommend bringing the laptop to a professional if you have no experience with opening laptops.
Oct 17, 2008 | HP Compaq Presario 1700T Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
