Question about Philips 55PP9401 55" Rear Projection Television
Goes dark with a little red. Then comes back on as normal and goes black again etc.. Living here in the caribbean no ones knows what to do.When looking in the tv I see all lights on but not bright when it goes dark. Th PIP is however when small, clear. What to do?
Same problem!
Posted on Aug 23, 2008
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
After booting my screen goes dark
Goes dark or just stays dark ? if stays dark then it is the GPU causing problems as it has got too hot at some point, possibly due to lack of ventilation underneath. What sometimes works for me is to turn the machine on and flip it over and rest it on say a tea towel, but have the screen overhang the edge of table so it doesnt damaged it. Then, you need to cover vents and let the machine heat up for say around 10 mins. After this time, turn machine off and back on again, and you will find the screen will come back on. You should then be able to use machine as normal, but keep all vents clear. Some folk might think this is barmy, but trust me it works on most, HP, Compaq, Dells etc.
Apr 07, 2010 | HP Computers & Internet
I have a Mitsubishi WS-55313 55 in. Rear Projection HDTV. My problem is, the picture suddenly goes to a black screen, while the audio remains. When I turn the TV off, and then back on, I may or may not get...
your dose not use lamp, it is a crt driven TV . One of com problems for that model was loose connection on one of the yokes. When that normaly happens , there is a sudden flash and screen gose dark and sometimes it can flash back if not you get red light blinks. If you you know where the yokes are at check little small board . A small mirror will come in handy, access from front of TV. adios ... john
Mar 31, 2010 | Mitsubishi WS-55313 55" Rear Projection...
The transmission fluid is dark red looks odd to me
sounds like you have disintegrated one of the clutches in your transmission and are running bare plates against eachother, get that transmission rebuilt or replaced
Feb 25, 2010 | Chevrolet Blazer Cars & Trucks
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Picture has gotten darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
Repair of digital camera
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
Nov 14, 2007 | Nikon Coolpix 5700 Digital Camera
Philips 55PP9401 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
