Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego projector my ciego tuen of on its on in like 30- 40 min. its not tha bulb because tha lamp replacment screen po up and i know its not hot cause u out a extra fan to keep it coo... my d 1000 plays for about 40 seconds and then shut off. when it goes thru the shut down process you can turn it back on and it does the same again. I only have about 500 hundred hours on it. i need to know what to do to correct the problem
    Genius:
  • 3,422 Answers
HI,
The problem can be with the two things:
1)Bulb
2)The unit is overheating which is causing it to shutdown after 30min or so.
So what you can do is first replace the bulb and try.If not it is an overheating issue and the only solution for that will be to switch to another unit or get it repaired.
If you need anymore help let me know.
Goodluck,
Please don't forget to rate or accept the solution
Posted on Jun 11, 2008
    Brigadier General:
  • 3,614 Answers
Try reset the lamp settings.. / lamp timer..
    Genius:
  • 1,447 Answers
Hi-
Chances are its the bulb, or its the fan/ or unit that is overheating? where is your projector located? is it ina cubicle, ceiling or on top of a table, try to check the filter and clean it, if you can change the filter, might as well change the air filter, its either at the bottom or side of it, try taking out bulb and put it back it but be careful it might be hot let it cool for ahile first. If nothing change, then what your having is already a hardware issue, contact manufacturer or have it service if out of warranty. Best i got!
pls rate as fixya if helpful, thanks!
    Master:
  • 638 Answers
Go for a hard reset and try.
  • hemant somaiya
    hemant somaiya Jun 11, 2008
    There could be a whole number of things that is the cause.
    The most popular of which would be replacing the lamp or Ballast ( lamp's powersupply )
    Could you supply me with the LED status when the unit shuts down ?
    rate this solution as fixya if this helps u any way so this will encourage us to solve more problems for you. thank u for using fixya.
    Master:
  • 555 Answers
500 hours is actually a lot. Replace the bulb.
When powered up picture comes on very dim then it turns off but unit fans stay on for 5 minutes then shuts down all the while the power button is flashing.
You most likely need a new light bulb. The bulb is an Osram P-VIP 180/230w. Just google it, or here is a link to it: http://www.purelandsupply.com/D1000-Bulb-Cinego-Lamp-Bulbs.html They cost about $180 new. Good luck!
PS - Be sure NOT TO TOUCH the bulb when you replace it. The oil in your finger skin will cause the lamp to fail early.
Nov 29, 2010 | Radio Shack Cinego D-1000 Multimedia...
When i turn on my projector it stays on for a few seconds
On your Cinego remote, push the setup button (bottom row, second from the right). Using your number keys and their corresponding arrows (7, 0, 9, 5), move to management, and then down to "lamp reset." Push enter (8) and follow the prompts. Always be sure to use Economy Mode (top of the management list) each time you turn on the Cinego to drastically increase your lamp life.
Jul 06, 2009 | Radio Shack Cinego D-1000 Multimedia...
I NEED A lIGHT BULB FOR MY CINEGO PROJECTOR
You can see the link below for your Cinego Projector. Since you did not specify the model I did a generic. If you need more specific info for a specific model you can reply via comment.
http://www.purelandsupply.com/Cinego-Lamp-Bulbs.html
Aug 27, 2008 | Televison & Video
Line through center screen
You have an issue with your bulb... (probably defective). I would suggest you get another one.
Here is the cheapest on out there right now
http://cgi.ebay.com/Cinego-Radio-Shack-D1000-D-1000-DLP-TV-Lamp-Bulb_W0QQitemZ200244942111QQcmdZViewItem?hash=item200244942111&_trkparms=72%3A570%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14&timeout=1218473411446
Jul 21, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego projector
Hi daddieATX
This could be the Ballast ( lamp's powersupply ) that will need replacement if the lamp is still ok.
May 18, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego turns itself off after 10 mins
Hi There
Check if your lamp has any faults like discolouration or marks on it.
Otherwise it could be Mainboard that will need repair or replacement.
Apr 16, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego projector lamp
dimmed or gone out!!! there is a setting for economy mode that will make it not as bright.
Feb 27, 2008 | Radio Shack Cinego D-1000 Multimedia...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
144 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
