Question about HP 1040 Plain Paper Inkjet Fax
Brought new ink , but still saids it low
I just replaced the ink in my machine , but the screen still saids it's low. I unplugged it and wipe the machine with alcohol. What should I do ?
Reprogram the machine/printer then reinstall the driver and then try again. if still not work replace the ink cartridge be sure you cant touch the sensitive part of it.
Posted on Jul 02, 2008
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My dell all in one 948 printer always have low black ink. After I put in a new black ink and after five prints the indicator said low black ink. Please provide a solution.
The ink sensor is malfunctioning, make sure the area it plugs into(contacts and ink port is not dirty fouled or clogged up and that any plastic or strips are removed that are supposed to be removed, a cotton swab dipped in alcohol goes a long way with printer problems. make sure its unplugged and hold the power button down for a few seconds before touching any sensors for safety even unplugged machines can hold a charge in them.
Jan 14, 2010 | Dell 948 All-In-One InkJet Printer
My canon pro 9000 is spitting ink on prints
I would start by removing the printhead and wiping any ink carefully from the bottom surface. Next unplug machine while the carriage is in the center, way over on the right is a wiping assembly that wipes the bottom of the printhead. Wipe any excess ink off these wipers with a q-tip or paper towel. Should help...
Jun 25, 2009 | Canon PIXMA Pro9000 Photo Printer
Machine won't print
Scanner failure means that the scanner bulb is no longer working. There are a few things that can sometimes bring it back but it may be a permanent issue.
1) Make sure printer is directly into the wall and not a surge protector or power strip
2) Remove cartridges from printer
3) Unplug power from back of printer and wait 30 seconds
4) While printer is unplugged press the # and 6 keys and plug power cord in. Keep holding # and 6 until the printer has either powered off or it says semi-full reset
5) Go through initialization process - if it works great the issue with firmware is fixed. If not then the scanner bulb isn't functioning and you are looking at replacing the unit.
May 11, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
Brought c5180 two 1/2 years ago. starting using product 8 months ago, printed maybe 500 pages. replace ink when needed. now printer say i need to replace cyan ink which i did twice. brought it in for...
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover c00372271.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Or Please let me know what is the exact error message you are getting.
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
The screen on my Cannon MP600 displays the following reference and message: "U043" and "The following ink tank cannot be recognized." This applies to all of the ink cartridges. None are...
Replace the ink tanks and make sure they are snapped in / seated properly.
Try cleaning the contacts between the cartridges and the cartridge carrier.
If the problem is not solved, unplug the printer for half a hour, try again. Try restoring the printer to defaults.
Hows your warranty?
Nov 11, 2008 | Cannon Office Equipment & Supplies
Edweard
Take all carts out. Close cover. Unplug machine from power. Wait a minute. Plug in machine to power. Machine demands carts. Insert new (!) cart as demanded from machine. In case when asked push 1 for YES: cart changed.
BTW:
Always print until machine stopps printing. Display says NO INK XY. After replacing the cart machine will print the rest data out of its memory.
NEVER change cart when machine says low ink (This is only a hint to buy a new cart!). At this point the cart has about one third of ink left!
Nov 01, 2007 | Brother MFC 420CN All-In-One InkJet...
Ink says empty but cartridge is new
On the phone for an hour with those idiots in India, same exact problem. Here is what you do: 1: Unplug AC cord from back 2: Hold down the # and 6 key, plug in the powe cord and continue to hold the kes for 1 minute. 3. Printer will power off durning this time. Release the keys and plug in the power cord. 4. You may need to press the power button on. This will hard reset the printer. It will go throught the initialaztion process and suck your cartridges but should solve the problem. HP SUCKS!
Jan 05, 2007 | HP Photosmart 3310 Printer
HP 1040 Plain Paper Inkjet Fax Logo
87 people viewed this question
Seeker5211
Seeker5211
