Question about Dell Inspiron 1000 Notebook
DELL 1000 INSPIRON CMOS BATTERY
WHERE IS CMOS BATTERY LOCATED
  • Anonymous Mar 13, 2014
    cmos battery location
    Genius:
  • 2,028 Answers
Should be one of two places on the Dells. Look under the memory cover, if not under the keyboard. If you still can't find it, go to Dell's support site and pull a system diagram. If you haven't already, it's very helpful to know what the bat looks like. Dell uses a few different types.
Posted on Jun 11, 2008
3 Suggested Answers
  • 37 Answers
SOURCE: cmos battery on dell inspiron 4100 model PP01L
Reserve Battery Removing the Reserve Battery notice.gif NOTICE: The reserve battery provides power to the computer's RTC and NVRAM when the computer is turned off. Removing the battery causes the computer to lose the date and time information as well as all user-specified parameters in the BIOS. If possible, make a copy of this information before you remove the reserve battery. notice.gif NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries. notice.gif NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer. notice.gif NOTICE: Read "Preparing to Work Inside the Computer" before performing the following procedure.
  1. Remove the hard drive.
  2. Remove the keyboard.
  3. Disconnect the reserve battery cable from the system board connector.
  4. Pry the reserve battery free from the system board. The reserve battery is attached to the system board with a piece of adhesive tape.
  5. Remove any remnants of the adhesive tape from the system board.
reserve battery
speaker connector
Replacing the Reserve Battery
  1. Connect the reserve battery cable to the system board connector.
  2. Position the reserve battery above the speaker connector on the system board.
  3. Update the BIOS using a flash BIOS update program floppy disk or CD. For instructions on how to flash the BIOS, see "Flashing the BIOS."
this information was found on the following page which might be useful to you in the future.
http://support.dell.com/support/edocs/systems/ins4100/en/sm_en/remove.htm#1090379
Posted on Sep 30, 2009
SOURCE: Dell Inspiron 1000 notebook - where is the CMOS battery located
underneath the keyboard, pull the top plastic line cover (the one covering the power button) then two screws and pull it off carefully, the ribbon connection will pull out pretty easy but be carefull not to twist it.
Posted on Mar 26, 2009
How do you get to the cmos battery on a dell inspiron 1545 laptop
It's located just below the RAM modules on the bottom side of the motherboard.
Mar 06, 2016 | Dell Inspiron 15 Laptop
Inspiron 1000 doesn't save cmos settings
Hi
As you said that you haven't used the computer for long time then it could be the motherboard which has gone faulty not the HDD or DVD.
Try to use the new HDD with this old motherboard.
Or else you can seek help of Any Geek Squad or computer vendor.
In case if you have any more trouble do contact back in Fixya.
Thank you
Sep 05, 2012 | Dell Inspiron 1000 Notebook
Hi i am using Dell inspiron 1545 laptop. I unable toenter in Bios. how to break administrator password in dell inspiron 1545 laptop
there is no default password for that you will need to open up the laptop and remove the cmos battery inside to bring the bios back to its factory settings (without password). sometimes tho dell will add password , dell , or admin as a password. but thats usually for laptops and pcs they sell in bulk to businesses
PLEASE let me know if this helped and sorry for the bad news about having to open up the laptop
Mar 16, 2011 | Computers & Internet
I need to replace the cmos battery on my dell inspirion 1000. I know where it goes, I just need a replacement. do you happen to know the battery number. Thanks
Hi rsulsr, the #number of the CMOS battery should be written on the top of the battery. Write down the part / model number and you be able to replace it. Thanks for using Fix' Ya. If this helped, please let me know by giving a "Helpful Rating;" thanks again.
Nov 30, 2010 | Dell Inspiron 1000 Notebook
How to remove a cmos battery is a dell inspiron
The CMOS battery is located underneath the keyboard of your Dell i5100.
If you're up to it, then try these simple steps:
- Open the lid to a 180 degree angle and using a very small Flat Screwdriver, pry the hinge cover on the right side. There's a small notch where you can pry it out.
- Check if the keyboard is being held by 2 screws. To loosen them, remove the battery and unscrew them from inside the battery bay.
- Carefully lift the keyboard in an angled position and check the ribbon or contact tape that connects the keyboard to the motherboard. Flip the keyboard towards you and see if you can reach the CMOS battery (usually covered by a blue plastic shield or protective cover. There's a pair of wire coming from it and the end is a small connector. You may remove the connector attached to the motherboard carefully to get the CMOS battery.
Jun 10, 2010 | Dell Inspiron 5100 Laptop
Does the dell inspiron 100 have a CMOS jumper? If so what does it look like or where can I find it?
just remove the keyboard and see that somewhere below have to be the bios battery ..if you remove it it will have the same effect ..some models have a switch for the cmos..but Inot all..jumpers are rare on laptops..if there are should be the only one..it is written clr .cmos ..near ..and it is placed under the keyboard..
May 28, 2010 | Dell Inspiron 1000 Notebook
How to remove battery on dell inspiron 1150
From Dell manual MAIN BATTERY
"Slide and hold the battery-bay latch release on the bottom of the computer, and then remove the battery from the bay. "
Image -
http://support.dell.com/support/edocs/systems/ins1150/sm/begin21.jpg
CMOS battery is located on the systemboard and requires disassembling the computer
Nov 02, 2009 | Dell Inspiron 1100 Notebook
Dell 5100 cmos battery replacement
The CMOS battery most likely is a button battery, probably a CR2032 lithium battery. The battery could be located on the bottom of the laptop behind one of the panels or under the keyboard. There is no MOP, when you remove the battery it may default to the factory defaults (depends how long the battery has been removed) and you need to go into the BIOS setting to set the Date and Time etc.
Jun 05, 2009 | Dell Inspiron 5100 Notebook
Mar 26, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
1,458 people viewed this question
Alun Cox
