Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 The screen flashes colors like a strobe light and the lamp light is on
  • 1 more comment
  • canchaser Jun 11, 2008
    How do I get to the supply board?
    Do you think it could just be the lamp?
  • canchaser Jun 13, 2008
    The lamp was changed about a year ago. I was wanting to check the board to see if I could visibly tell if that was the problem before ordering a lamp
    Is it better to purchase a bad board or have it repaired?
    Problem Solver:
  • 16 Answers
Check the 2 3300 mf/ 10 volt capacitors on power supply board.
visible examination of these caps will often show the top of the capacitor bubbled up.
Posted on Jun 11, 2008
  • coffeedrunk Jun 12, 2008
    hi canchaser
    first of all, a bad lamp will cause the lamp indicator to come on but usually will not cause the strobe effect.Has the lamp ever been changed before? if so how long ago?
    I;m a little reluctant to go into the procedure to get to the power supply because I don't know how familiar you are at replacing solder in components.
    These tv's over the last year or so have developed several different problems due to leaky capacitors. Not only the 2 caps in the power supply but there are 4 capacitors on the DM board and sometimes 4 caps on the formatter board that can become leaky.
    If your not confident in what your doing I would contact an AUTHORIZED Mitsubishi servicer. These problems are addressed in a series of bulletins.
    As for an estimate of repairs, that's a hard question. I've been in the service business for 36 years and estimates for the same repairs can vary greatly. To change the capacitors on the power supply board in the home would probably be around $300.00
    Good Luck,
    coffeedrunk
  • coffeedrunk Jun 13, 2008
    canchaser
    i seriously doubt the lamp is the issue. i'm still leaning towards the caps on the power supply board. there's quite a bit of disassembly to get to them. as for the caps on the dm and formatter board, forget it. I know you don't want to hear this, but i still sggest you go with an authorized mitsu servicer. changing this board is not necessary just the capacitors. you probably couldn't get the board yourself seeing how you would need Technical Assistance to authorize the purchase. if price is the issue I would call an authorized servicer and ask them if their familiar with the capacitor issue and prod them for a rough esimate for repairs
    Good luck
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My WD-52525 started a rubbing noise coming from the back area. I figure it's the light engine. Color was off and it won't restart, has a lamp light now. Lamp is 4 months old. Sound like light engine?
This sounds like your color wheel. this will affect the colors on your screen. Do check your lamp though, at 4 months you still should have a good lamp. Unless you have a bad ballast affecting the lamp as well. If you hear a rapid clicking or an electrical buzzing type noise. "ballast"
Apr 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 62927 not turning, no picture...
It sounds as if you have the lamp unit out. Had the same problem myself. Sorry.....
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wierd sounds coming from fan
If it is a grinding sound, or a sound you might consider painful to listen to for more than say, five seconds--it's your color wheel.
The color wheel in most MITS DLPs can be replaced on its own. However, in some cases, you need to replace the whole Light Engine.
Expect to pay $400+ for the Light Engine and $250+ in labor for someone to install it.
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Feb 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
