Water Pump
REMOVAL & INSTALLATION
CAUTION
Never open, service or drain the radiator or
cooling system when hot; serious burns can occur from the steam and hot coolant.
Also, when draining engine coolant, keep in mind that cats and dogs are
attracted to ethylene glycol antifreeze and could drink any that is left in an
uncovered container or in puddles on the ground. This will prove fatal in
sufficient quantities. Always drain coolant into a sealable container. Coolant
should be reused unless it is contaminated or is several years old.
2S-ELC Engines
Fig. 1: Exploded view of the water pump mounting
with gasket. Replace the gasket.
Fig. 2: Water pump bolt loosening sequence for 2S-ELC and 3S-FE
engines
few times with a rubber mallet.
engine contact surfaces are clean and install the new O-ring into the pump cover
groove.
to 82 inch lbs. (9 Nm).
glycol based coolant. Start the engine and inspect for leaks.
3S-FE Engines
housing.
cover.
engine and install the three bolts. Tighten the bolts in an alternate pattern to
82 inch lbs. (9 Nm). Install the by-pass pipe attaching nuts and tighten them to
82 inch lbs. (9 Nm) also.
5S-FE Engine
pulley.
then pull out the water pump and cover. Remove the gasket and two O-rings.
Fig. 3: Bolt removal sequence for 5how to replace the water pump - 89553g46.gif
To install:
with soapy water and then connect the pump cover to the by-pass pipe. Do not
install the nuts yet!
the three bolts to 82 inch lbs. (9 Nm), in sequence (top, bottom, middle).
Install the two by-pass pipe nuts and tighten them to 78 inch lbs. (9 Nm).
component to specifications.
2VZ-FE and 3VZ-FE Engines
and then remove the inlet pipe and O-ring.
To install:
0.08-0.12 inch (2-3mm) bead of sealant to the groove in the pump and then
install the pump. Tighten the bolts to 14 ft. lbs. (20 Nm).
Fig. 4: Apply sealant on how to replace the water pump - 89553g47.gifof the water pump as shown
component to specifications. Connect the radiator hose and fill the engine with
coolant.
1MZ-FE Engine
spanner wrench, remove the bolts to the right and left camshaft pulleys.
Separate the pulleys from the engine. Be sure not to mix up the pulleys.
block.
how to replace the water pump - 89553p75.jpgr />
Fig. 5: Unbolt the No. 3 timing belt cover from the engine
Fig. 6: Water pump mounting bolt and nut locations
Fig. 7: Pull the water pump from the engine and remove it from
the vehihow to replace the water pump - 89553p78.jpgmg src="/uploads/images/89553p77.jpg" alt="89553p77.jpg" class="h_mi" />
Fig. 8: Always discard the old gasket
To install:
coolant leakage.
block.
nuts. Tighten the nuts and bolts to 53 inch lbs. (6 Nm).
and start thhow to replace the water pump - next.gif.
For
complete water pump replacing procedure, step by step, there are few help
links.I suggest you to refer the help links.
Click
the link below:-----
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
These
will help.
Thanks.
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
How to route Water Pump Belt for 1992 Oldsmobile ?
How to replace Water Pump on Car ?
How to Remove Water Pump?
Where is Water Pump located ?
This will help. Thanks
provided below.
provided below.
This will help. Thanks.
provided below.
provided below.
provided below.
provided below.
How to route Water Pump Belt ?
provided below.
How to route Water Pump Belt?
