Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
I need a CD to install but i dont have one
I dont have a CD to istall the 2wire 802.11g wirelss USB adapter is there any other way to install it??
  • 18 more comments
  • kotaman Jun 14, 2008
    Is there anyone out there that know how to install the adapter without the CD that comes with it?
  • kotaman Jun 16, 2008
    what do i do from there?? at http://www.2wire.com/?p=266
  • kotaman Jun 19, 2008
    Yes it is on that page but what do i do from there?
  • kotaman Jun 20, 2008
    Yes
  • kotaman Jun 21, 2008
    k what next
    oh fyi i am on a different computer accessing the internet and the computer that i am installing the usb driver does not have an internet connection.
  • kotaman Jun 22, 2008
    what about CD-ROM's?
    how do i upload it? there are 3 files in the folder that i downloaded from the site that opens with CAM UnZip
    http://www.2wire.com/?p=331
    When I DOwnload It it is called 2Wire_wireless_USB_XP32.zip
    and it wants me to unzip it and there are 3 files inside
    ZD11BUXP.SYS
    ZD1211BU.CAT
    ZD1211BU.INF
    how does plan b work?
    where do i select options for the network devices??
    after i finished the wizard it read
    "The following hardware was installed:
    [ZD11211B] IEEE 802.11 b+g USB Adapter
    The software for this device is now installed but may not work correctly
    This device cannot start (code 10)
    To close the wizard click finish"
    I started the Add hardware wizard then clicked yes i have connected the hardware, went down to the very bottom of the list and clicked on "Add a new Hardware Device" then clicked install the hardware that i manually select from a list, then i clicked "Show all Devices" then clicked "Have Disk..." then selected the c:\2wire folder then it installed then gave me the error above.
    maybe i did something wrong
    maybe i downloaded the wrong one. i downloaded h 32bit one for windows xp. how do i know what one to download??
    i dont know what you need so ill give you all the info on the back
    FCC ID: M4Y-XG702B
    P/N: 1000-100056-000
    Input Voltage: DC 5V
    H/W REV: 1.0
    MAC:0060B3-F82030
    S/N: XG72B61WU002128
    kk i sent u a picture of it from my e-mail kota_man@hotmail.com
    K i got the info filled out from earthlink so you should be able to see it now!
  • kotaman Jul 05, 2008
    The picture looks just like the one at the top of this page
  • Anonymous Aug 09, 2008
    I have the same problem as kotaman, the network adapter just won't install. My computer won't recognize the device and the add hardware wizard won't use the drivers I downloaded from the 2wire website (for me it's the vista x64).
    I've followed the steps listed by Bubbabear64 but none of them have worked so far, but I do appreciate his help :)
    I'm wondering if there was some ending solution to this problem since the last message at June 23. Thanks for the help!
  • 20 Answers
The problem is, that 2wire and AT&T, like most companies that get too big for their britches, **** big fat eggs! I found the drivers by using archive.org to view a past version of "www.2wire.com/?p=410", which looks to be the last version of their legacy drivers page. The driver and manual links for this adapter and others are there, but archive.org doesn't host files. You have copy and paste just the 2wire part of the direct links for the drivers from archive.org. Not surprisingly, the files are still right where they were on 2wire.com, they have just removed the page that links them.
At some point 2wire will probably remove the files, but until then, here they are: Windows XP http://2wire.com/pages/drvrs/twwgusb_2.3.1.3.exe http://2wire.com/pages/pdfs/USB_Adapter_Driver_Installation.pdf
Vista Driver http://2wire.com/pages/drvrs/TWWGUSB_TEMP.exe http://2wire.com/pages/pdfs/WindowsVista_Wireless_USB_Adapter_Driver_Installation.pdf
User Guide http://2wire.com/pages/pdfs/802.11g_USB_Adapter_Installation_Guide.pdf
Posted on Dec 22, 2009
  • snowhuouv Dec 23, 2009
    Well now I feel dumb... I just noticed that the legacy drivers link is still on the 2wire page. Sorry 2wire :) I think I must've been so mad after scouring AT&T's website that when I finally got to 2wire.com I couldn't see the link right under my nose....
    Moral of the story...don't post when you're mad
  • 2,794 Answers
  • 13 more comments
  • Tim Babcock
    Tim Babcock Jun 16, 2008
    Does your product appear on this page:
    This is different than the last one I gave you.
  • Tim Babcock
    Tim Babcock Jun 19, 2008
    Do you see your model number on that page?
  • Tim Babcock
    Tim Babcock Jun 20, 2008
    Click on the driver link next to the picture and download it.
  • Tim Babcock
    Tim Babcock Jun 21, 2008
    If you have a jump drive you can dowload it from one computer and upload it to the other.
  • Tim Babcock
    Tim Babcock Jun 22, 2008
    Can you send my the link you are using to get these files?
  • Tim Babcock
    Put those files onto a folder your hard drive called 2wire. You will have to create the folder.
    If you plug the device in and it searches for drivers have the installation wizzard point to c:\2wire. It should read ZD1211BU.INF first and then the other two if it needs it.
    If that doesn't happen I'll tell you how plan B works.
  • Tim Babcock
    Press the control panel. Select add hardware. Select yes I already connected the hardware. See if there is anything with a red x or a yellow circle. If that matches your network device click on it and have the drivers install from the c:\2wire folder.
    It no network device is found press back and select No I haven't added the hardware yet. If it doesn't detect it after this, select the options for network devices, press have disk, select the c:\2wire folder. Then plug the device in.
    You will have to restart the computer once install is completed.
    If this doesn't work, there is something wrong with that device and it should be looked at. It may have a power problem.
  • Tim Babcock
    Resart your computer and see if that recognizes it.
    It almost sounds to me after going through all that trouble there might be something wrong with it.
    Where did you get it at?
  • Tim Babcock
    It could be the wireless device isn't working. Do you have a way of getting a new one?
  • Tim Babcock
    Your doing it the correct way. I think there is something wrong with the wireless device.
  • Tim Babcock
    Whats the model number of the device. I'll go the site and check it out.
  • Tim Babcock
    Can you send me a picture of the wireless device to timbabcock@earthlink.net?
    I want to make sure I got a good match for it.
    I might give their tech support a call too.
  • Tim Babcock
    I have to approve your address for earthlink. Then I should be able to take a look at it.
    Thanks,
    Tim
  • Tim Babcock
    Tim Babcock Jun 23, 2008
    I'll get back to you on this.
  • Tim Babcock
    Tim Babcock Jul 05, 2008
    I'm glad youre back I had a funeral to take care of and lost track of you. What was your facebook page to see the picture.
    I noticed there were two other people this with 2 wire issues this week. I have a feeling this product is heading on the down spin.
Http://www.cedevice.com/2WireUSB.htm
The link above has files for installing 2wire ver 1.0 usb G wireless adapter. It worked for me. Just follow the read me file. I turned on wireless zero config in the services menu and used that method to set up the wireless settings.
Posted on Sep 08, 2008
This is called the 2Wire Legacy USB Version. The driver is located at url: http://support.2wire.com/index.php?page=download
Posted on Sep 03, 2008
2 Suggested Answers
uzi9mmauto
  • 17 Answers
SOURCE: how do i install my 2wire 802 11g usb wireless
The Link im giving is for WIn 98,2000,XP etc and Vista.
Both Version of 2wire 802.11g USB Wireless Adapter Drivers are Here:http://www.youtube.com/watch?v=pgGovtiQp3g
Video Explains,Links you and comes with Installation Pdf manual.
Take care
Posted on May 25, 2010
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
How do i install my 2wire 802 11g usb wireless adapter without the installation cd
Take care
Feb 23, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
How do i install the 2wire usb wireless adapter without the cd?
Got to:
http://drivers.alege.net/6924/2Wire-80211g-USB-Wireless-Adapter-Driver-Windows-98SE-ME-2000-XP-download.html
and download the free self-extract installer - twwgusb_2.3.1.3.exe
READ the Readme_first.txt and follow the 2-step instruction.
NO NEED FOR A CD!
Aug 06, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire 802.11 usb without 2wire gateway
http://support.2wire.com/index.php?page=download click on the adapter link for the driver and instructions. If you dont see the picture of your adapter, then click on the legacy link on the adapter page. After you install the software just use the icon on the lower right to connect to your wireless network.
Jul 11, 2009 | 2wire Computers & Internet
I have a desktop and laptop I want to know if I can use the Wire2 Wireless usb adapter to create a network that the laptop can access and how to do this
first of all u hav to get a internet connection in ur home,,ur internet provider will provide u with a modem,if tat modem has wireless capabilities then u dnt need to purchase a router otherwise u hav to do so.then u have to setup the wireless modem or the router and the 2wire wirelss USB adapter on the same wireless network.plz keep me posted for further issues
Feb 21, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I need to setup the 2wire adaptor for my computer but lost CD
Google the term "ZD11BUXP" to dwonload this windows update and it shall resolve your problem
Jan 19, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire wireless usb adapter installation for desktop
elomarcillo1,
You are attempting to install a (brand name) 2wire wireless usb adapter, normally the SBC DSL CD is ONLY what you would use to set up your SBC DSL modem. You should have a specific 2wire CD that you put in your CD Drive when you want to install the 2wire wireless usb adapter. Can you locate this CD?
-ms
Nov 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
I am having a problem with 2wire diver
I had to reload my computer and I don't have the install CD for my wireless 2wire. Where can I get the info to reinstall data?
Jun 15, 2008 | 2wire Computers & Internet
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
5,882 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
