The washer turns on and fills and works properly until it get to the part of the cycle that sprays detergent into the machine. Water begins to flow out of the drawer and goes everywhere. I haved leveled the machine twice and nothing seems to work. HELP!!!
I'm not familiar with your machine but usually there are nozzles above the soap drawer which squirt the water on to the detergent compartments at the appropriate times . If you can take out the soap tray have a look to see if the nozzle bit has come loose and is pointing towards you...also check that the outlets from the soap tray are not clogged with...soap.
Failing that, you could partially turn off the water supply to the machine so the pressure is reduced. Sure it will take longer to fill, but you won't get so wet.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Is it possible to remove the front rubber seal for the mouth of the Eurotech 172 for deep cleaning....
(More)
Is it possible to remove the front rubber seal for the mouth of the Eurotech 172 for deep cleaning. The design traps water and is difficult to clean.
I have a Eurotech EWF172 it will spin ok without a load in it but will not spin with even a small...
(More)
I have a Eurotech EWF172 it will spin ok without a load in it but will not spin with even a small load?????
washer refuse to spin after a wash and after we tried a second wash and it refuse to completely fill...
(More)
washer refuse to spin after a wash and after we tried a second wash and it refuse to completely fill up
The on/off switch won't stay on when pushed in. It needs to be held in place (with duct tape!) to...
(More)
The on/off switch won't stay on when pushed in. It needs to be held in place (with duct tape!) to run the wash cycle. I want to get the cover off to check the switch. How do I do that? Any other ideas about the switch?
my eurotech m110 does not turn in the wash cycle with clothes in but spins when empty. The motor...
(More)
my eurotech m110 does not turn in the wash cycle with clothes in but spins when empty. The motor works well
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
