Question about Clarion RDB325D
How to adjust treble and bass
I bought a car with a Clarion RD83250D stereo.  It sounds aweful.  Can anyone tell me how to get to the  bass & treble adjustment?  Thanks.
  • alazan05 Dec 08, 2008
    sounds like my treble (dash) speakers are blown , they are brand new, i cant seem to adjust it right.
  • Anonymous Mar 13, 2014
    como ajustar bass y treble en mi clarion
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
Posted on Mar 09, 2009
How to adjust bass and treble and surround sound
On the Remote Control
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
The tone cannot be adjusted in the direct
3 Press
to select an item to be set, and use
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
I cant figure out how to set the sound, bass, treble, etc..
hi Rob, here is the user manual, page 13 and 14(of the manual) tell you how to manual adjust bass, treble, fading, balance etcHope this helpsShona
Apr 10, 2012 | Clarion DXZ665MP CD Player
How come when i push the "A-M" button to use my sound controls all i get is the balance and the fader? no bass and no treble
You can only use bass and treble if your Z-Enhancer is OFF. If it is on excite or bass boost you cannot adjust bass or treble
Oct 14, 2010 | Clarion DXZ665MP CD Player
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
4) the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Finding treble and bass adjustments on my stereo
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
Good Luck Please Rate FixYa!
Dec 19, 2008 | Alpine CDA-9835 CD Player
How the heck do I adjust the radio sounds (Bass/Treble)??
in newer sound systems they usually have an button that says audio with push of the button it should give you options of adjusting balance fade bass treble etc.
Aug 27, 2008 | 1999 Porsche Boxster
Stereo Sound
You could start by adjusting the Treble and Bass. The treble is what makes the high notes more nodicable, so if you turn the Treble up you should be able to hear more vocals. The Bass is what makes the low notes more nodicable, so if you turn the bass down you should be able to stop the shaking which I'm guessing is the low notes. On the other hand if you have an aftermarket radio then there might be a Mute or ATT button. Theses are for instant quiet, just repress the Mute or ATT button and it should be fine. I hope I could help.
-Andrew Hawkins
Apr 09, 2008 | Panasonic CQ-C1100U CD Player
Car Audio & Video Logo
287 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
