Question about Sony PlayStation 2 (PS2) Console
Vibration function I have two PS2 systems that work fine. When I plug in the controllers they do not vibrate (on either system). I check that the vibration function is on for the game, but it still won't work. I don't know what else to do.
  • Anonymous Jun 12, 2008
    I have one Ps2 console but vibration function is not working.
  • me1224 Jun 13, 2008
    I have tried both ps2's with different games, but each time, the vibration doesn't work.
  • 54 Answers
Try a different game, either its the controller, the game, or worse would be your ps2 is busted.
Posted on Jun 13, 2008
My core controller just vibrates
Hi
The problem may be with the game. some PS2 games are partially compatible with PS3.
When the controller vibrates and turns off use the wire to switch it on and keep running.
Jul 02, 2013 | Nyko Raven Motion Sensing Wireless...
THE VIBRATION OF MY PS2 IS NOT WORKING. HOW CAN I LOCATE THE PROBLEM AND SOLVE?
If your ps2 controllers aren't vibrating anymore then this could be the fix that you were waiting for.
WARNING: Make sure that 1) Its not your controller that is broken, test it in a machine that does have vibration. 2) Make sure that the vibration option is turned ON in your games
If you are sure that your controllers aren't broken, then you may have blown a fuse inside your ps2 on your mainboard.
To fix it you have to remove a blown fuse from the ps2 mainboard and either put a new fuse there or replace it with a piece of single strand wire. The point is fairly small so you need a fine tip soldering iron and a single strand of wire. It may be best to get someone who is good at soldering to do this fix for you:
I take no responsibility for anyone breaking their ps2 when performing this fix. All I know is that i've done it and it worked a treat!
You will need;
1) A fine tip soldering iron and some thin solder.
2) A single strand piece of wire, something thin like kynar or enameled wire.
3) A game with vibration function to test the ps2 afterwards.
4) A controller that works with vibration.
Between the power supply connector and the PS9 fuse there is a small black square with 2 silver prongs on the left hand side. This featured on my mainboard as well, and I was able to locate the correct / broken fuse using a multimeter. Look for a fuse with S7 on the top near here, and check for continuity, If there is none then thats the one! One last thing before it goes into full detail;
Check the track between the black square with the silver prongs and the broken fuse, if its on the same track then you can attatch one end of the wire to that prong that is on the same track, and the other side to the end of the fuse opposite of the black square with silver prongs *
This will take bout 10 mins to do - start to finish.
Below tells you how to do it
Below is a description on where and what to look for i.e. the fuse, and how to repair it.
1. I have a V5 PS2
2. Take the PS2 apart.
3. Remove the Power Supply motherboard.
4. After removing the Power Supply Board, you will need to remove the metal shroud and expose the entire PS2 Motherboard.
5. Once you have done this look around the connector for the Power supply board on the PS2 mother board. You will see a number (maybe around 4 of them all located within 2 inches of the Power supply connector) of fuses with "S7" written on it.
6. The one you are looking for has the text "PS9" written on the motherboard next to it.
7. Check it with a multi-meter, for continuity, there will none. If you are not sure, you can check all of them, when the buzzing on multi-meter stops, that's the one.
8. To repair it, use a strand of wire, possibly from an old extension cable or something, but only one strand. Solder it on both sides of the fuse in order to close the connection.
9. Reassemble the PS2.
10. Boot up and play your game, vibration is back.
Hope This Helps
Apr 07, 2011 | Sony PlayStation 2 (PS2) Console
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
I have a fat ps2 with a rumble controler problem
just keep ure ps2 safely and always shining . so always clean ur ps2 and make the best use of controllers carefully
Sep 19, 2009 | Sony PlayStation 2 (PS2) Console
My PS2 controller does the same.
its vibrating because it is probably grounded.. check for stuck buttons...try opening it and check the rubber underneath the keys
Sep 06, 2009 | Sony PS2 Dual Shock 2 Controller...
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Vibration malfuction
The controller will still function as normal,
But inside there is a BENT / CROOKED / weighted, spinning mechanism in one of the protruding grips... that often straightens or gets stuck.
The only way to fix it is to take it apart - EASY!
Putting it back together is - NOT!
firstly, spray the pins with a contact cleaner.
May 08, 2008 | Sony PlayStation 2 (PS2) Console
PS2 SLIMLINE
check the connectors on ps2 side so that there may be a dry solder or a loose connector
Jan 01, 2008 | Sony PlayStation 2 (PS2) Compact System...
Ps2 dualshock analog controller not vibrating
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Ps2
The special fuse inside the PlayStation unit is broken. If you need more info please advice.
Mar 31, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
162 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
