Question about Dell 924 All-in-One InkJet Printer
Fax for printer
Does the I924 Dell printer has a fax in it
  • 197 Answers
Not likely..only the all in ones have that option
Posted on Jun 14, 2008
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
How do you find fax log for sent faxes on Dell 962 All-in-One
Only faxes sent and received by Fax Console can be seen by Fax Console. View the Status of a Fax Using Fax Console or Fax Service Management
  1. Click Start All Programs (or Programs) Accessories Communications Fax.
  2. Click Fax Console or Fax Management Services.
  3. The following folders appear:
    • Incoming - faxes currently being received
    • Inbox - faxes that have been received
    • Outbox - faxes scheduled to be sent
    • Sent Items - faxes successfully sent
  4. Click the folder of your choice.
  5. Click the fax in the right pane for which you want to view the status, and then click Preferences or Properties.
  6. Click the General tab and view the Status line.
  7. Click Close when you are finished
Mar 05, 2011 | Dell 962 Photo All-In-One InkJet Printer
How do I print out my fax history from my Dell V505 Printer
The Dell Fax Solutions Software allows you to:
  • View fax history.
    Click View full activity log to see or print a detailed list of all fax activity.
  • Create a fax report.
    Click Print activity report to see a detailed report of all fax activity. Click the Print icon to print your activity report.
  • To access the Dell Fax Solutions Software:
    1. In Windows Vista:
      1. Click Start® Programs.
      2. Click Dell Printers.
      3. Click Dell V505.
      In Windows XP and 2000:
      Click Start® Programs or All Programs® Dell Printers® Dell V505.
    2. Click Dell Fax Solutions.
      The Dell Fax Solutions Software dialog box opens.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 05, 2011 | Dell V505 All-In-One Printer
    SET UP DELL 948 ALL IN ONE PRINTER AND WON'T FAX BECAUSE WHEN I SET INSTALLED THE FAX I PUT IN A 1 AS PART OF THE DIAL CODE AND EVERYTIME I TRY TO FAX SOMETHING IT PUTS A 1 IN THE FRONT OF THE PHONE...
    Unplug the printer from the PC.
    Uninstall the printer, reset the computer, install again the driver and connect the printer again, then configure correctly the fax.
    Done.
    Thanks.
    Dec 11, 2010 | Dell 948 All-In-One InkJet Printer
    My dell all-in-one printer won't receive faxes
    did you complete the set up process (cd software)? if yes..on the front panel of all in one go to advance fax set up...(do you have an answering machine?...set the fax to pick up on one less ring than the answering machine....(the answering machine picks up on 5..set fax to pick up on 4)...the fax number is your telephone number...hope this help...feel free to rate
    Jun 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
    How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
    1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
    964
    Dell All-In-One Center.
    2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
    Display the Printer Setup Utility.
    Printer Setup Utility Tabs
    On this tab: You can:
    Send • Enter your name and fax number.
    • Select a maximum send speed and a print quality for outgoing faxes.
    • Choose whether to scan the entire document before dialing the number.
    • Choose whether to use error correction.
    • Select when to print a fax usage report.
    • Select when to print a fax activity report.
    this information is from the manual found here
    http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
    I hope this helps
    Mar 12, 2009 | Dell Photo 964 All-In-One InkJet Printer
    Using fax
    Please go to the Dell Printer site using this link, where you can get all the useful information:
    Dell Printer How To Fax
    Let me know if you face any difficulty or need any assistance.
    Regards
    Ellin
    Sep 26, 2008 | Dell 924 All-in-One InkJet Printer
    Fax name
    Hi c_mcnair, when you install the software for you're A960 printer it also installed the Dell All-In-One Center. Within in the dell center you can change you're fax settings. To open the dell center do this, Click Start → All Programs → Dell Printers → Dell AIO Printer A960 → Dell All-In-One Center. Once opened click fax setup utility. Fax starting on page 40 in manual. Once in the fax setup utility you'll be able to change any & all fax settings. I do not have the software installed. If I did I could be more specific, step by step.
    (You can't find the back space button). If this refers to you're keyboard it's just above the enter key. It's the key with the arrow pointing to the left on it. ( <------ ).
    If you no longer have the user manual for you're Dell A960 you can download it by clicking on this link.
    http://support.dell.com/support/edocs/systems/a960/en/a960en.pdf
    You'll need Adobe reader software to read the .pdf file, AKA manual. You can download it for free.
    Click this link for Adobe reader.
    http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
    Good luck c_mcnair!
    Mike
    Jul 29, 2008 | Dell A960 All-In-One InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    19 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
