Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Lexmark X422-fax/copy maching
How to you change the date that is displayed on the machine?
My lexmark x422 does not activate. My previous OS was windows vista and the lexmark x422 was ok. Now my OS is windows 7 since i had to reformat and the lexmark x422 is not active.
As much I want you to enjoy your Lexmark X422 with your newly installed Windows 7. Lexmark company already discontinued this model and basically it will only works with Windows Vista. The printer does not support Windows 7 anymore, since there is no driver anymore for Windows 7.
I hope I answered your questions.
Thanks a lot!!
Aug 13, 2011 | Computers & Internet
Have problems finding the following drivers/updates for my COMPAQ CQ61z-300 notebook: Lexmark X422 Bluetooth Peripheral Device
If your computer doesn't automatically find the driver then you can manually update it. You can download drivers for Lexmark x422 using the link below. Just select the right operating system.
http://driverscollection.com/?H=X422%20MFP&By=Lexmark&SS=Windows%20XP
Jul 18, 2011 | Lexmark International Lexmark X422
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
When trying to send a fax a brother 1360 and after dialing the number rings but the document will not scan and displays 'telephone'.
The reason why your mahcine shows telephone because it can't recognize the document that you loaded in.
Try to remove the document from the feeder and make sure that your mach shows date & time. Load the document again in the feeder and the display should show enter fax # & start, that's the time you need to dial the fax # and hit the start key,
Hope this helps,
Mar 28, 2011 | Brother Fax-1360
Have changed phone service providers. they say that the fax mach. and land line can work together. I say i need another phone line for the fax mach. please help. the fax mach. is a hp 1040 fax. jeff h.
If they changed you over to Vonage or some other digital service, the fax machine will not work reliably.
You need a plain old telephone system POTS for your fax. All faxes are analog.
Nov 12, 2009 | HP 1040 Plain Paper Inkjet Fax
Can you change the fax speed on the Lexmark X422 mfp
Why would you want to change it?
When one FAX connects to another FAX, they "negotiate" the speed and capabilities, so as to guarantee a successful data-transfer.
As they negotiate, you may hear the "squawking" soon after the other FAX picks-up the call.
Nov 06, 2009 | Lexmark X422 All-In-One Laser Printer
How to set scanner local (stand-alone) on LEXMARK X422
Good morning,
Pleae follow the appended link to the Lexmak U.S.A. publication's page.
If you need the manual in a different language, go to www.lexmark.com. From there, selec the country then Technical Support > Publications > X422 MFP.
This link will take you to the English version of the User's Manual.
http://www.lexmark.com/publications/pdfs/x422/eng/userref.pdf
Don
Mar 10, 2009 | Lexmark X422 All-In-One Laser Printer
Can't receive or send fax on my lexmark X4270
In this case first we need to chk whether there is any dial tone on ur fax machine for that u need to Hit the Options button till u find an option saying On Hook Dial now hit select and it should give u a dial tone if it doesnt check the Phone Line Connections........... If it gives u a dial tone........... Unplug the Power Supply from the Printer........ Press and hold the Stop/Clear button and while holding the Stop/Clear button insert the Power Supply back to the Printer........ It will say clearing and then display a page where u need to Selct ur Country and the other details........ and as soon as this is done u can send and recieve faxes....... Thanku
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
