Question about GE WHRE5260E Top Load Washer
Overflowing GE Washer will not stop filling and begin washing cycle
  • Anonymous Jun 15, 2008
    My washing machine will not stop filling up.
  • Joe Grams Mar 24, 2009
    No debris in hose. Is there a way to service the plastic housing at the bottom end of tube?
  • 5,911 Answers
This is a symptom of a pressure switch problem. Open the console and double check the pressure switch (located behind the water level knob) and make sure the rubber hose is still attached. In many case, this hose vibrates loose and comes off the pressure switch. Without the hose attached, the pressure switch never senses the change in pressure from the wash tub required for it to be shut off. The end result: your washer continually fills without shutting off. If it is a simple hose problem, you can prevent this from reoccurring by placing a small zip tie around the air hose at the point where it attaches to the pressure switch. Do not over-tighten as you may damage the switch fitting. Just make it snug.
If the air hose is still attached, and the electrical connections are still attached, replace the pressure switch. I could not find a part number with the model number you listed this under. Please double check you model number again and post back, so I can assist you finding the correct part (if needed). I hope this helps you. Let me know if you have further questions.
Posted on Jun 11, 2008
I recently had the same problem. I checked the end of the air hose coming from the tub. It had a tear in it right at the connection. I just cut off the hose at the tear and placed the hose back on the connection.
Posted on Jul 18, 2008
Same problem...cleaned out the tube and now everything is fine.
Posted on Sep 09, 2008
Same problem. At first I had to drop from super to large and now the large overflowed. Hose was connected to the pressure switch but I tried blowing in it and it was restricted. I pulled the front cover and found the other end of the hose. It was clogged with 2" of dirt. I scrapped it out and it's fine now. Cleaning this tube will need a 6 month PM schedual to prevent future damage to my home from over spills.
Posted on Sep 01, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My old GE Profile top loading washer is overflowing during the fill cycle...It moves into agitation OK but doesn't stop the fill. I have to manually turn off the water during the fill. Fill switch works...
loosen the back screws and push the top forward, its got clips in front that just shift in, then you mast carefully lift the top due to the wires and vacuum pipe that control the level, just unplug the supply
Dec 12, 2010 | GE WPRB9220C Top Load Washer
The washing machine will not stop filling, overflowing on the floor.
Not knowing what brand of washer you have.......some fill by time, some by pressure. Sounds like a stuck timer, or bad float switch, or pressure switch.
Jun 22, 2010 | GE Washing Machines
When I start the washer it continues to fill up and wont stop
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which one is... while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..The inlet valve is normally located in the back of the machine where the hoses hook up. The pressure switch can normally be found inside the control panel with a small rubber tube attached to it. You should replace the faulty part. If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Water overflowing - GE wvsr1060a1ww top loading washer
since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Aug 16, 2009 | GE Washing Machines
Washer not going in cycles
Where you attached the new hose on the side of the tub, you must remove that hose and insert a small wire in the hole in the cup and clean out the soap scum. Re-attach the hose. Set the washer on spin and run a spin cycle. Then retry your wash cycle.
Make sure the new hose is not pinched anywhere.
Apr 24, 2009 | GE WJSR2070B Top Load Washer
GE Unitized Spacemaker Washer and Gas Dryer
It may be your pressure switch... it is what stop the water from over flowing the washer let me know if you want to change it yourself...I can help
Oct 24, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WJXR2080T2WW Washer Fills with water - then stops
older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Jul 22, 2008 | Washing Machines
GE WHRE5260E Top Load Washer Logo
103 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
