Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon MP530 alarm light and feed switch light
I started to print something and forgot to open the door to let the paper out. It completed printing then ever since the alarm light and feed switch light are blinking. I have tried unplugging and resetting the printer to no avail. Please help!:)
  • Anonymous Apr 02, 2009
    I would like to know answer to this question too.
5 Suggested Answers
SOURCE: Canon MP 160
how do you fix error 5100
Posted on Feb 20, 2008
geemarie
  • 876 Answers
SOURCE: Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Posted on Aug 24, 2008
SOURCE: Canon MP530 shows paper jam,
First – diagnose your problem. In my case the first roller which feeds the paper through the ADF (under small black flip up cover on top) was not turning. Hence no paper advance and error claimed a paper jam (it wasn’t – just a failure to advance paper)
The cause turned out to be a stuck gear turning that silver rod at the top. A bit of household oil has worked a charm.
To get at the gear, unhinge the ADF cover retaining tie (black flexible plastic stopping it opening all the way). Just lift it up and roll over towards printer.
Then unscrew one screw next to that tie. Gently prise plastic cover off by lifting up from left hand side (near that black tie). It should rotate off. Keep power on and fingers out.
Put a few drops of oil on top gear. Place paper in ADF and attempt a batch scan operation. Gears should turn and lubricate parts. Repeat.  Once working, replace cover, screw and tie.
Mine had seized months ago and is now working fine. Hope yours does too.
P.S. Get a Continuous Ink System (as sold on eBay) - awesome for an ink guzzler...
Posted on May 11, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
Everytime I go to print a document, printers, alarm comes on and it says error 6000. Im not sure what to do. Do I need a technician?
Yes you will need a technician. basically it sounds as if the timing **** disk has fallen off the end of the platen so the machine is not able to feed the paper or print.
Jul 04, 2011 | Canon PIXMA MP530 All-In-One InkJet...
MP530 - paper not feeding. don't see a 'slot' or 'guide' where paper should go
samaddar07.jpg The above pictures show how to open and set the Pixma 530 printer and also where to set the papers.The paper tray is in the upper panel, when you open the panel it becomes the paper tray as shown in fig.
Mar 31, 2011 | Canon PIXMA MP530 All-In-One InkJet...
ALARM light flashing, wont let me print.
hold down stop/reset button for 7 sec. If that doesn't work try holding it down for 14 sec.
Dec 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Paper jammed in canon MP530
finally got the paper out by unplugging the whole thing, removing it from the shelf, and taking out the spare paper tray on the bottom of the unit... sure wish it had been designed with a "release" button!
Nov 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Paper feed jamms the paper all the time, will not feed without jamming from bottom tray, top tray jams every 2 to 3 prints or print with the top corner bent
Unless both feeder rollers went bad at the same time, which is unlikely, it must have something to do with the paper. It might be slightly damp, or not the correct kind. Try using high quality matte white paper from a brand new pack and see whether it still jams.
Oct 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I was unsing my printer when it jammed. I cleared the paper however, the alarm light keeps coming on. I have tried turing the printer off, turning off the entire computer, turning the printer and computer...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 22, 2009 | Canon PIXMA® MP530 All-In-One Printer
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : eunice@idig.net
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
332 people viewed this question
old marine
old marine
Corne Viljoen
