Question about Dryers
Tumble dryer problem
Hi there, my tumble dryer works but it takes nearly two 120 min runs to dry bout 8 items od clothing. just t-shirts and smalls. checked the vent outside the house and there is no hot air or cold coming out of it! What could be the problem changed the hose a couple of months ago but didnt do much.
Kind regards
Breda
  • bredabear Jun 11, 2008
    Thanks a million, ill give it a try!!
    Kind regards
    Bredabear
  • 5,911 Answers
Please refer to the following link for detailed instructions on how to diagnose you dryer problem.
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you only changed the vent hose on the back of the dryer, it may not have been enough. Especially, if your vent line runs under the house, or through an attic. If you have long exhaust run from the point where the dryer connects to the exhaust, to where it exits your home, you may have a clog EXTERNAL to the dryer. You need to trace the exhaust line and locate the cause of the air flow blockage.
Try removing the vent hose on the back of the dryer and check for air flow. If you still don't have air flow, you have a clog INTERNAL to the dryer and you will need to open the unit and check the blower fan assembly under the lint screen. If you have air flow and still do not have any heat, please refer to the link I provided for advice on how to determine what may be source of the heating circuit failure. If you need further assistance, or have questions, please post back and let me know. I hope this helps you.
Posted on Jun 11, 2008
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
Hotpoint ultima tcd980 condenser tumble dryer not drying properly
this sounds like one or two of your stats (tod) for short have gone if you need more help get back ok
Oct 22, 2012 | Washing Machines
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
New Whirlpool Dryer taking too long to dry
Old dryers worked on the premis, "bake them til they are done". Newer dryers are all about saving energy. Newer dryers rely far more on airflow than thier predecessors. Most likely if your clothes are taking 120 minutes to dry for a new dryer, you have a ventalation problem. Make sure (even if it was "professionally" installed) that the vent from the back of the dryer to your wall in not kinked, bent over, or other wise restricted. Also make sure when the air is venting to the outside of your house you can feel a fair amount of air pressure there. Bulid up over time or even a nest being built in your vent can cause a restriction on airflow. These can be cleaned by a professional service or many appliance and hardware sell cleaning brushes and kits. Worse case scenario, Whirlpool will pay for customer instructs for the first 6 months. So even if they have to come out and tell you it's a problem with your house vent or electrical supply, whirlpool can be billed for this. Of course if there was a manufacture defect off the production line, repairs are still covered under warranty as well.
Jun 21, 2008 | Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
