Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher (older model)
Dishwasher will not drain. What would the troubleshooting diagram for this?
  • Kenmore Master
  • 5,568 Answers
It could be a firm clog in the exit hose but you should be able to hear the pump running during the last portion of the wash & rinse cycles.
If you don't, then the pump has likely failed.
Posted on Jun 29, 2008
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Trying to troubleshoot the circulation motor before I have to dismantle the dishwasher. It is built in and would be a MAJOR project to remove.
Go to Sears, parts, and many times they have the schematics there to pull up and print. This is one of the reasons I keep buying a portable...fixing is a pain when permanent!
Mar 05, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Water is not drain completely after wash.
Jun 01, 2011 | Miele 24 in. G870 Built-in Dishwasher
Water won't drain out from bottom. Any ideas to troubleshoot?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 03, 2010 | GE 25 in. GSC3200Z Free-standing...
Won't drain
http://appliancejunk.com/forums/index.php?topic=2936.0
Please find above your service and repair manual. This has diagrams etc, to assist you with what you need to do.
Below is a self help website to assist you to troubleshoot and hopefully repair your issue.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Often it is the actual pump itself that gets stuff Clogged into it, and needs to be dissembled and cleaned.
Jul 30, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
Check if any of these is the problem..
1)Drain hose is kinked or house drain is restricted.
Straighten the drain hose to improve water flow to the drain.
2)
Standpipe is too high.
Standpipe must not exceed 96 inches in height.
3)
Drain hose has been taped (or sealed) into the standpipe.
Tape holding the hose in the standpipe should not form a complete seal. The standpipe needs air for proper draining. Remove some of the tape to make an air path.
4)
Drain hose fits too tightly in the standpipe.
There must be an air gap between the drain hose and the standpipe for proper draining. The standpipe needs to be at least 1 1/4 inches in diameter.
Oct 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
224 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
