Question about Kitchen Ranges
No power to clock face or main oven - Kitchen Ranges
  • Anonymous Jun 12, 2008
    No electric power
  • barbrian Oct 16, 2008
    We have no power after moving the range. no lights, fan nothing. any solutions for us?
    Genius:
  • 1,073 Answers
If you have power to the clock on l1 then replace the control
Posted on Jun 11, 2008
PROGRAMMER/CLOCK, WILL NOT LIGHT UP, BOTTOM OVEN WILL NOT LIGHT UP. PLEASE HELP.
Hello;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have no power.
This could be something simple such as a blown fuse.
Or, you could have a bad main board.
Did you have a power outage?
I can not tell you anymore because you did not provide a model number, which is located on a metal plate on the face of your unit when you open the oven door.
Go to your breaker box. Turn power off to your range for 10 minutes. Then turn the power back on - trying to reboot the control board.
Mar 23, 2015 | Ovens
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Elements work but both ovens and clock face are off
Reset breaker or unplug and restart stove. Open back of stove to clock face and make sure the harnesses are tightly fitted to clock board. You could even remove and reinstall the harnesses to the clock board.
If able, check for 120v to clock. If clock is getting power but not lighting up, replace clock.
You did not say whether the clock controls the oven; ie. oven does not work when clock is off. if so, replace clock. If not, ignore it unless you want to know the time from that clock.
Oct 20, 2013 | Maytag Gemini® MER6765BA Electric Kitchen...
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
Oven stopped working after big power surge. stove still works but oven will not turn on and nor does digital clock
Both the oven and the clock are controled by the main board. The power surge probably destroyed the main board.
Jan 31, 2011 | Kenmore Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Display clock failure so no main oven
check you have power to clock and if not, check wiring back to find out why not. to get oven working, you can bypass the clock by joining the two wires to the clock relay. these clocks are remarkably expensive
May 07, 2007 | Zanussi ZCG7680 Gas Kitchen Range
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
