Question about Kaito KA1103 SW/FM/AM Radio
DE1103 The radio worked fine, After a few months the volume control stop working. The volume set it self on 40. If I push the " VOL " , the " VOL " indication on the screen stats blinking but turning the tunning knob has no effect, It remains at 40. I'll apreciate any help, Doxi My e-mail : doxi
    Problem Solver:
  • 7 Answers
You should try pushing the reset hole with a unfolded paper clip, or leaving the batteries out of the unit overnight
Posted on Dec 31, 2010
Horn buttons works the radio
Suspect a short circuit in the steering column wiring
Jun 20, 2016 | Cars & Trucks
Volume doesn't work on bose radio in car all the time
I had the same issue with a car I owned and had to replace the unit.
May 04, 2017 | 2009 Nissan Rogue
Navigon easy 40 no sound
The usual problem is the voice volume is turned down. This can happen when you are adjusting the volume down just as turn by turn instructions are starting; thus you don't notice it happened, or someone else did it or software glitch caused it or Murphy's law.
The way to fix it is turn vol up to max and set navigation and start driving. As you get to navigation points where you would expect the turn by turn instructions hit the up volume button. Keep trying it will only go up whilst instructions are being broadcast. Try using repeat last directions function to get a better shot at it.
This happened to me and this was the fix, odd but true.
Also see if there is a turn by turn vol level in settings.
Hope it works for you.
Aug 12, 2012 | Navigon 40 Easy 4.3" Sat Nav With Western...
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
We have two radios with problems, one the volume is to low and wont respond to vol control and the other has a problem with the transmit button,sometimes it works fine other times not
On the radio with the low volume, it is possible you are having a low receive (Rx) issue, or you have a bad volume potentiometer. It would need to be seen by a radio technician to determine the exact cause and if it can be repaired. In most cases, the flat rate repair for this style of radio is around $69 ea.
Your second radio with the transmit button (PTT) issue likely has a failing push-to-talk internal button, or a broken spacer behind the rubber plug. These would be common failure parts on this type of radio and replaced during a repair.
Best regards.
May 10, 2011 | Motorola XV1100 (1 Channel) 2-Way Radio
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I have the same problem .The controler has to be replaced .
Where to get one is my problem .
Jul 05, 2008 | Kaito KA1103 SW/FM/AM Radio
Open Questions:
Kaito KA1103 SW/FM/AM Radio Logo
309 people viewed this question
Top Kaito Audio Players & Recorders Experts
Level 1 Expert
xxxxxx xxx
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
