Question about Sharp Office Equipment & Supplies
Hi, I got error code vk on sharp mx-m850 copy machine. Does anybody know this code and how to fix it? Thanks a lot. Raymond
5 Suggested Answers
  • 6 Answers
SOURCE: im getting an f2 error code in my copy machine sharp 2020
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
Posted on Nov 26, 2008
007tech
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
tunde007
  • 2382 Answers
SOURCE: SHARP MX 5500 COLOR COPIER,
Hi, it is a fuser temperature error or one of the sensors is dirty. You could try removing the fuser assembly - ensure power is switched off- then try cleaning the sensors as they tend to get paper dust and melted toner which collects between the surface which senses the heat from the fuser `Hot` roller. if this does not fix it you may need to replace the fuser.
There is also an engineer code that you can enter to clear the fault but the code can only be given by the technical department of Sharp if you are lucky because they don't usually give it out, they prefer you replace the fuser....
Posted on Oct 27, 2010
lilgto64
  • 3 Answers
SOURCE: Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Posted on Oct 11, 2012
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What means E7-20 error code for sharp mx-m850
The code refers to the laser beam detection in the laser assembly.
The first thing to do is completely power the machine off & then back on to see if the machine resets. If it doesn't reset then the fault lies with the laser assembly itself & would require a technician to strip the machine to locate the problem.
Dave.
Jan 20, 2016 | Sharp Office Equipment & Supplies
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
We are getting a VK maintenance code on our MX-M850 copier. Does anyone know what it is and how to fix it?
This is one of the scheduled maintenance codes. it comes on at a certain "milage" and requires a technician to reset it.
If you're in Houston we'd be happy to help you out, and supply new machines should you need any.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp MX-2700N Color Copier
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
TA code
TA is like the universal maintenance counter, on this model only one code is displayed at a time. hold the copy key to figure out how many copies have been made on your machine and then call your
Sharp dealer they can tell you what is do to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Mar 27, 2014 | Sharp Mx-2600n MFP Copier
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
Sharp mx-2300N printer error maintenance required code vk
Dec 23, 2009 | Sharp MX-2300N Color Copier
Feb 04, 2009 | Sharp MX-2700N Color Copier
104 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
