Question about Avaya Definity 6408D Corded Phone
Change time on phone
How do I change the time on my 6408D phone. Is it done on the phone or via the Phone system console?
Thanks
Edwin
Phone system console. Contact your system admin, as it depends on exactly which system you have.
Posted on Jun 13, 2008
SOURCE:
Want to disable outgoing calls on avaya 6408d
well.. we use a definity and i use site administration and on the station account its self i have a COR setup to restrict the phone from dialing out. if you want help and have the same system let me know.
Oct 02, 2009 | Avaya Definity 6408D Corded Phone
Changing name on display
You have a Definity system, unfortunately, these are very high end systems, and you will need to contact your system administrator as it needs to be changed via the computer that runs your system.
Apr 16, 2009 | Avaya Definity 6408D Corded Phone
AUTO ANSWER PROBLEM
You need your system administrator to change that on a phone system level.
Cheers
Jan 30, 2009 | Avaya Definity 6408D Corded Phone
Moved user, need to change extension at new desk for avaya 2420 phone
Have your system admin movethe extensions ports. You have a definity or S87xx series.....that is the only way.
Jun 13, 2008 | Avaya Definity 6408D Corded Phone
Phone does not work with new port
Definity systems can have so many different types of phones. Can you plug another 64xx phone in and it works?
Mar 25, 2008 | Avaya Definity 6408D Corded Phone
Change ringtone
With the handset on the hook press the conf button (the one with three phones on it).
The phone should ring with your current ringtone. Each press of the conf button will advance to the next tone.
pick up the handset and put it down again to select the ringtone.
I think there are 8 to choose from.
Mar 21, 2008 | Avaya Definity 6408D Corded Phone
Change clock display??
Press Feature.
Dial _9#.
Enter hour and minute via dialpad.
Press Recall to change AM/PM setting.
Press Hold to change to calendar setting.
OR Press Feature to exit this feature.
Press Recall to select day of week.
Dial # to move the cursor to day of month field.
Enter day of month via dialpad.
Press Recall to select month.
Dial # to move the cursor to year field.
Enter last two digits of year via dialpad.
Press Feature.
This must be done from a phone with attendant features set. Typically ports 1 and 2. More than likely x10, x100, x1000 or something like this.
Mar 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
PICK UP GROUPS AND HUNT GROUPS
You will need to talk to the phone administrator. It needs to be set up in system admin.
Nov 08, 2007 | Avaya Definity 6408D Corded Phone
Changing the display
In your system support room - - you will have two computers set up for your phone system - maybe (at least that's how it's set up here).
One is for the voicemail system and one is for the phone display, essentially.
You will log in to that other station and when you get the command prompt type
change station xxx (where xxx is the extension of the phone display you wish to change).
Sep 13, 2007 | Avaya Definity 6408D Corded Phone
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
Avaya Definity 6408D Corded Phone Logo
528 people viewed this question
Top Avaya Lands Phones Experts
martin hogg
Ekse
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
