Question about Gateway GT5228 PC Desktop
All USB ports dead....
The only change that happened was moving the PC to a house out of an old apartment. However, after restarting at the new location USB ports do not recognize new devices when plugged in, even though they show 'ENABLED' - NAS drives, video cams, etc. The solutions I have tried: 1.) reboot the machine; results - the same; 2.) Uninstalled the USB boot devices from Hardware Manager, rebooted and hardware was recognized and installed - results - still do not function.
Anything else, before I go out to buy PCI card replacements?
  • markmeth Jun 11, 2008
    THough I haven't taken the side cover off yet, it looks like it has both PCI and motherboard USB ports; there are 4 in the back next to the sound and video input/outputs, which I assume is a PCI card then also. There are 3 more ports in the front.
    This is the description from the device manager under Universal Serial Bus Controllers:
    Standard Enhanced PCI to USB Host Controller
    Standard OpenHCD USB Host Controller
    USB Root Hub
    USB Root Hub
  • steve quelnan
    steve quelnan May 11, 2010
    Is the old USB Ports you were using were connected to a PCI Card, or directly connected to the Motherboard it self?
    -mrsolution
  • 70 Answers
Try removing the PCI USB Adaptor and clean the gold contact with dry brush, then place it back again. If this still doesn't work, try moving the PCI USB Adaptor into other available PCI slot.
I hope this procedure solves your problem.
-mrsolution
Posted on Jun 11, 2008
  • steve quelnan
    steve quelnan Jun 11, 2008
    Also, when pluging-in any of your USB Device like printer, please plug it one-by-one, plug device one 1st then wait until the driver is install, then next, and next.
Cannot get it to connect to hp laptop
Have you tried with a another mouse?
When you plug the mouse, something happens on the computer?
It's a special mouse who need special drivers to works?
Jan 07, 2016 | HP Computers & Internet
How do i keep usb live on imedia s2185e1 when switched off
I found this on an internet search:
"If you are running Windows 7 the USB ports can be powered down using Selective Suspend.
Start > Control Panel > Power Options (if not visible change view to Large Icons at top right) > Change Plan Settings (for whatever plan you want) > Change Advanced Power Settings > Change settings that are currently unavailable > Set USB selective suspend setting to Disabled under USB settings and then click OK to save the changes.
You may have to reboot."
Feb 07, 2015 | HEWLETT-PACKARD Computers & Internet
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a HP Pavilion G70-250US Notebook that suddenly starting having USB recognition issues. It started with the USB receiver for my wireless mouse. Suddenly it stopped working and I started getting...
no operating system even stated.
Xp/vista/w7/w9/w10/ linux ,what.... must we guess?
is your internet connection working? it must or PNP will be near brain DEAD ,do that first.
ok guess w10.
why not see if OTHER USB works first
barrow a real mouse not that battery dead wireless wonder mouse?
get a real mouse
make sure that works
then put in a new battery in your wireless mouse
RTM it tells you how
USB tests, all so obvious.
use real desktop key board , that work
or USB memory stick , add file to it, see other files you have there>?
only clues here is USB dead, 2 months old.(means new? or new to you?)
next,
in w10
go to CP
then go to device manager
be ONLINE
see yell or red error there that driver stack?
bingo bad driver
reload any that are bad.
end story
google how to reload a windows 10 driver, be like 10,000,0000 hits.
Mar 15, 2017 | HP G70-250us Notebook
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
Usb ports loose and now wont work
Even taking a laptop apart (to board level) is tough, but you need to order the USB socket on ebay and solder the new one in carefully. Are you a qualified miniature soldering expert?
Jun 30, 2009 | Dell Inspiron 8600 Notebook
Additional USB ports not recognised
seems that none of the ports are working
Jan 19, 2009 | ASUS P5PE-VM Motherboard
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
HP 1317 all in one
Unplug theprinter usb cable from the pc
restart
reinstall the drivers
plug printer into different usb port
Jul 12, 2008 | Microsoft Windows Vista Ultimate Edition
Fixing optical mouse problem
try a diff mouse. try a diff usb port
Jul 31, 2017 | HP OPTICAL SCROLL MOUSE (8131)
Gateway GT5228 PC Desktop Logo
220 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
