Question about Dell Dimension 2400 PC Desktop
Hard Drive - Adding 2nd Hard drive
I figured I add a 2nd hard drive to my comp. After connecting the 2nd hard drive, I was messing around in the BIOS screen and accidently save the changes and I believe I turn on one of the slave drive. Then when it restarted it would just sit at the dell splash logo screen and wont go any further. I hit the F2 but still nothing. Did i mess up something in the BIOS? And how would I get pass the dell splash logo screen to even access the BIOS screen?
Could something also be wrong with the both the hard drives? I did accidently touch it, which I know I'm not suppose to.
Appreciate any help or advice I can get. Thanks
  • quiksilver49 Jun 11, 2008
    hey i really appreciate the help. I will try that out and see how it goes.
  • quiksilver49 Jun 12, 2008
    Thank you guys. Problem solved :-)
    I appreciate your time.
    Scholar:
  • 160 Answers
Hello
1. Did you remove the jumper to the second HDD
2. Did you place the jumper for the first HDD in the Primary master
3. Press the Del or F2 key to enter the BIOS.
Let me know that your problem is solved and rate me as Fixya!
Posted on Jun 17, 2008
  • 191 Answers
Just open the system tower and there you will find a coin cell battery just remove it and put it back
it will reset the BIOS defaults.
for opening your system log on to
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
enter your system model or put in the service tag
you will find a bar coded sticker which has a 7 digit alphanumeric number its either located on the right side of the tower or may be at the back where all the cables are connected
once you reset BIOS do remember to go to system setup again by pressing F2 button at as soon as you power it back on and disable the floopy drive as it will display a message regarding the discket seek failure
Posted on Jun 11, 2008
  • 70 Answers
Try re-setting the CMOS setting, use the jumper to reset.
-mrsolution
Mba3073np jumper setting
http://www.fujitsu.com/downloads/COMP/fcpa/hdd/MBA3xxxNx_Jumpers.pdf
Diagram and user-selectable options (on NP models only)
Below is a diagram of the main board of SCSI HDD and also a summary of the user-selectable options including guidelines for installation
of the HDD.
hope this helps
Oct 04, 2012 | Fujitsu (MBA3073NP) 73.5 GB SCSI Ultra320...
My second internal hard drive isn't showing up under my computer, but show in bios, and add harware Maxto 4R060J0 60gb
Your 2nd. hard drive needs to be set up as a slave or master, this is done by the jumper in back of the drive. If you have a cd drive as a slave when connecting with the ide ribbon & are connecting the new drive on a different ribbon it needs to be set as master drive. A little more info on your prob. will help answer your question. When you see the drive in bios, does it say master or slave?
Lee
Dec 18, 2009 | Maxtor Hard Drive
Computer did not bootup after adding 2nd harddrive
Did you connect the drive to cable spot closest to the motherboard on the primary IDE channel? is it formatted? Did you try the drive on the Second IDE channel? Can your system support a 160 GIG drive?(if not try partitioning the drive.). Is the power and data cable connected properly?(the red line on the data cable should be closest to the power plug on the drive.)
Apr 11, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
Hard drive not installed
Did you install this Hard drive,,,did you set the jumper pins in the proper position i.e: Master - Slave - cable select??
If you did nothing to the computer and it's losing the hard drive,,then it could be the Cmos battery going dead,,make thge bios lose it's saved settings.
Jan 17, 2009 | Dell Dimension 2400 PC Desktop
What 2nd "Slave" hard drive should I buy to match my "Master"?
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Dec 29, 2008 | Mobile Rack - 3.5 Inch Hot-swappable...
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
I have a Maxtor 6Y120Lo internal hard drive which is my "C" drive it is nearly full Can I add another hard drive and double my "C" drive
You can add another hard drive, but it won't double your C drive; it will just show up as another hard drive.
However, using a program like Acronis, you can hook up the 2nd hard drive, make an exact image of your c drive on the new drive, then connect the new drive in the old drive's place and there you have added more space on your c drive as it will automatically become the c drive.
Jul 05, 2008 | Computers & Internet
Installing 2nd Hard drive
Sounds like you have them both set to 'master' and is doesn't know which one to boot from.
Jan 15, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Dell Dimension 2400 PC Desktop Logo
160 people viewed this question
Alun Cox
