Gold Star window A/C R5207Y3 Evaporator ice buildup
Have had this unit for about 5 years, recently the front of the evaporator freezes over with ice and cooling capacity is lost. Followed troubleshooting guide to reduce thermostat setting and this worked but as soon as I turn the thermostat back to cool the ice forms. Is she just tired or is there something else I can do?
Thanks, Bill
  • turtlecurls Sep 06, 2008
    I'm also getting ice visibly on a lot of the fin area & coils. About half the fin area doesn't have ice. I've been suspecting low freon since spring before this started anyway. The air didn't seem quite as cold & was staying on longer & it's a very old unit that has needed a top off every one in a while in the past. It must be 5 years since I've called someone.
    Earlier I cleared the overflow tube out, but that was a wasted effort. It did seem to be running slow.
    I just hope the repair man will be willing to top it, instead of insisting on a new unit or leak testing. It is a slow loss.
  • kamailei_200 Apr 25, 2009
    i have the same problem, but the ice covers the evaporator, almost completely, and the coils on both the right and left side......i never tried to turn the thermostat down? or was it up? i also dont know where the "overflow tube" is either. i also don't know if a few of the fins being bent has anything to do with the fact that the air blows cool, not cold anymore. how would i know if the freon is low or not? please help me, summer is around the corner, and i cant stand the heat. mahalo!
  • 525 Answers
This is njormally an issue with oversizing but this should have manifested itself the 1st time you used it, unless you have relocated the unit. If you have reinstalled it in its original location and if you have cleaned the coils as required, then you have a low freon issue that only a professional should resolve.
Tip: If the ice is building up in 1 small area and not evenly across the complete evaporator coil, then you definitely are low on freon.
Posted on Jun 11, 2008
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Ice buildup by evaporator fan down into drain in back of unit. I melted ice using steam and heat, but it has happened 4 times.
Your defrost id not working, you didn;t leave a model so that is all I can tell you now
Mar 26, 2016 | Refrigerators
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
Ge side by side refrigerator freezes then immediately thaws
replace the evaporator thermistor located on the top of this coil behind the inside freezers rear cover panel,it looks like a small 22 caliber bullet and has 2 small white wires protruding from the one end,this reads the evaporator coil temperature info and determines when to defrost the evaporator coil,a good way to test it is to open the control board in the rear of the unit unplug the upper right J1 connector and measure pin 1 and 5 for resistance of approximately 16,000 ohms when the thermistor is un-clipped off the evaporator and immersed into a glass of ice water for at least 5 minutes prior
Nov 15, 2012 | Refrigerators
My window ac unit keeps cycling off, before it gets to the assigned temperature. Help
What may be at issue is evaporator icing. Some units cycle the compressor, others control the refrigerant to keep the evaporator temp just above freezing. If allowed to continue the evaporator would freeze over and air flow would stop....
Check and see if that is the case...
Jul 20, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Everything seems fine,but evaporator freezes up after about an hour.any idea?
Sounds like an air flow problem.......... Dirty Filter, not all of the supply vents open, return air blocked, Evaporator coils dirty, Blower motor quiting after it runs for awhile Check run capacitor.
Check to see if you are getting an even frost pattern.... if you are not , may be low of freon Thermostat set to low not letting the unit cycle off...... Are you running the AC with low ambient conditons outside..... Which will lower the head pressure which will lower the suction pressure and get the evaporator coil down under 32 degrees which will cause it to freeze up So take your pick it can be any number of problems....... Hope this helps.......
May 26, 2011 | Dometic Rooftop RV Air Conditioner
Hi we have an LG 232 SBF fridge freezer and the fridge section has recently stopped working. The freezer appears to be ok and there is a very quiet hum coming from what I assume is the compressor/pump unit...
You will need to check the evaporator it may be iced up. Two things may cause this the evaporator fan motor may be bad or the condensate drain could be clogged and causing the water to freeze on the evaporator. When the evaporator gets iced the air can't pass over it and get cold.
Aug 23, 2010 | Refrigerators
My Coleman rv mach3 63134cst which is about 3 years old won't cycle and freezes up when it runs to long. Ice forms on coils.
If coils are clean, or have been cleaned recently, then check your discharge side of unit for restriction. It may require you to take down ceiling assy, to be sure that there is nothing blocking the duct work inlets, if it is a ducted system. Also if ducted system, make sure you don't have too many blocked/shut off. As well you should have a freeze probe, or round sensor in the coils at front where intake filter goes over, (evaporator) to sense the frost, and kick compressor out until it thaws. When was the last time the evaporator and condenser (rear) coils were cleaned?
May 16, 2010 | Coleman Mach III Air Conditioner
Ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Jul 08, 2007 | Haier HWR06XC5 Wall/Window Air Conditioner
Heating & Cooling Logo
881 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
