Question about Pitney Bowes Hewlett Packard HRK-300 Black Refill Kit (for Apollo : P-1200 / P-1250i / P-2100U / P-2150U, Apollo ... Printer
Apollo p-1250i printer
Lights flashing, just changed cartridge, will not let me print. what do i do
  • 1 more comment
  • moonbaby Jun 11, 2008
    Wont work for me either
  • Anonymous Jun 25, 2008
    driver windows xp
  • brendajean Jan 15, 2009
    Apollo 1200 printer. Changed the cartridge but the light will not stop flashing and it will not print. Tried unplugging the printer but still did not work.
  • Pitney Bowes Master
  • 2,794 Answers
Unplug the power cord wait a few seconds and plug it back in
Posted on Jun 22, 2008
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Installation of Apolo P-1200 on windows vista
I HAVE PRINTER EPSON STYLUS C91 HOW CAN I INSTALL INTO MY LOPTOP WINDOWS VISTA
Nov 13, 2009 | Pitney Bowes Hewlett Packard HRK-300 Black...
The orange light flashes even though I have changed the colour cartridge, The printer will not print
change the catr insecting unit and the cable together for it to work well. that the problem
May 23, 2009 | HP DeskJet 940c InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Reg. Installation of Apollo P-1200 Printer on Windows XP
This driver is provided by Microsoft and is included with the Windows XP os.
Installation instructions:
1: Click START, then click on PRINTERS & FAXES
2: Click on ADD A PRINTER
3: At Welcome screen click NEXT
4: Select LOCAL PRINTER (if printer is attached directly to computer) and click NEXT
5: Choose LPT1 (in most situations) or a different port if not LPT1 then click NEXT
6: Select Apollo in left window
7: Select Apollo P-1200 in right window
8: Click NEXT
9: Type name for printer or accept default name
10: Click No to "Do you want to print test page".
11: Click FINISH
12: Test printer by sending a print job to printer.
If you experience problems after installing this driver, please consultthe printer user manual for proper lpt bios settings. eg: spp, ecp,etc. and change the lpt pc bios settings to match manufacturer'ssuggested settings. quote.gif Jerry K View Public Profile Send a private message to Jerry K Find all posts by Jerry K reply.gif
Mar 04, 2008 | Pitney Bowes Hewlett Packard HRK-300 Black...
469 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
