Question about Canon Office Equipment & Supplies
Copy paper drawer will not slide into unit - Canon Office Equipment & Supplies
  • Streamteamer Jun 11, 2008
    Sorry, for my first post, I am new. We have a Canon CFX-L4500IF Fax Machine. When we slid out the paper tray, it cannot be slid back in. The tray was originaly slid out as the alarm icon was flashing. Any assistance would be most appreciated.
    Scholar:
  • 130 Answers
Look inside the machine where the tray slides. You may have to tilt upward slightly then push in
Posted on Jun 11, 2008
Can I remove the paper tray on C7280 - if so how?
You could try removing all of the paper in the drawer and use flashlight to look into where the drawer slides in. There might be some plastic "tabs" there that are designed to prevent the drawer from coming out too far. They may be preventing pushing the drawer back in and if you use something strong and thin, like a knife blade you can push the tabs (try not to break them) out of the way and slide the drawer in.
Hope this helps.
Sep 21, 2014 | HP Photosmart C7280 All-in-One Printer
Can't get the paper drawer to slide in all the way on my Kodak printer ESP 7250
Did you add alot of paper? sometimes if drawer is too heavy it wont go in right. Make sure nothings blocking the gides and no paper jam in the back to why its not sliding in.
Jan 13, 2013 | Kodak Office Equipment & Supplies
Minolta di520 error code C0990
C990-C994 3rd drawer lift up and 3rd drawer elevator motor failure.Check the actuators and two motors .
Removal of the 3rd drawer:
1.Press the paper descent key and slide the 3rd drawe out to the front.If pressing the paper descent key does not allow you to slide out the 3rd drawer,insert a screwdriver or similar object trough the hole in the rear cover and unlock the drawer.
2.Remove 4 screws on the slide rails and pull the 3rd drawer out to the front.
3.Unplug 1 connector,loosen 2 thumbscrews to remove the connector board assy and remove the 3rd drawer.
4.Remove 4 screws,unplug one connector and remove the cover.
5.Remove two screws and the drive bottom cover.
6.Check the gears.
Aug 13, 2012 | Office Equipment & Supplies
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
When the paper drawer is fully-loaded and inserted properly, the "load paper" light blinks indicating that there is no paper (hence you cannot photocopy). However, when you pull the drawer out,...
if you remove the paper tray and you look in the slot that the paper tray slides in you should see a sensor flag hanging down remove the flag, it seems that the sensor is faulty the machine should work but wont let you know when the paper is finished so the very last page will show paper jam
Mar 18, 2011 | Toshiba 1370 Black and White Copier
The paper drawer is stuck on my new Samsung CLP 310
Turn the printer off. Unplug it completely. Very Carefully, roll the printer onto one side. Push the paper drawer in as far as possible, then, by grabbing the bottom of the paper drawer, and the front of the drawer with your opposing hand, slowing slide the drawer to release the pressure and slide it out at the same time. Pressure from the rollers pulling paper from the drawer will jam the paper between the drawer so tightly that the weight of the machine will act as a clamp. When your remove the weight of the machine by rolling it on it's side, you can slide the drawer out easier.
Nov 15, 2010 | Office Equipment & Supplies
C550 making a squeeking noise
A squeaking noise? The first possibility is a remnant of paper from a paper jam, causing the noise. You may be able to isolate this to a paper draw issue. To do this, remove all but one of the drawers. Do a test copy. Repeat this until all drawers have been eliminated. If it is a paper drawer issue, the take-up rollers (in the middle of the take-up edge) can be cleaned with a cloth dampened with mild liquid soap. If it isn't a paper drawer, the next possibility is the paper-path, up the right hand side of the copier. There are a number of 'doors' that can be opened. Check that the rollers and paper path is clean. If these two possibilities are eliminated the next issue is the fuser unit, the transfer unit, the toner cartridges or a cooling fan. These items should be directed to a service technician.
Sep 01, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Our PC1061 has been wonderfully reliable. Very recently we have 2 copier problems: One problem is there is frequent paper jamming coming out of the paper tray just below the toner cartridge and secondly,...
Hi:
Slide the drawer out completly and look into the cavity on the right side. You should see two D rollers that pick up the paper form the paper cassette. Clean these with alcohol. They an get dirty with time and cause paper jams.
Good Luck
Andrew
Jun 27, 2009 | Canon PC1061 Copier
Paper drawer won't open all the way and it won't copy
1. Turn the system off
2. Go to the right side of the unit and open the side panel will drop down
3. Move to the front of the machines and pull the drawer out as far as it will go, if it stops that meant there is a piece of paper caught in the take up area.
4. Go back to the side where you opened the panel and look for the lead edge of the paper, if you see it grab hold and up and towards you.
5. If you can't see the lead edge of the paper you will have to force the paper drawer out, just pull hard and the drawer and a piece of paper will come out.
6. Remove the drawer completly and then look in the paper drawer cavity for the remaining piece of paper.
http://www.websitetoolbox.com/mb/copierquestions
Dec 28, 2008 | Ricoh Aficio MP1600SPF Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
43 people viewed this question
old marine
old marine
