Question about Microwave Ovens
I have a goodmans microwave. a few weeks ago i opened the door and it blew the fuses. i have changed the fuse in the plug but still no power going to unit, please can u tell me if there is any fuses inside to replace.
    Genius:
  • 1,036 Answers
Firstly check the light.
As the light comes on when the door is opened - this could be the cause.
If that's ok, you could open it up to check the condition of the wiring, and that the door interlock is functioning.
As long as you don't damage anything, or remove the magnatron you should be fine.
I don't think there are any other fuses inside this model.
If it's anything else I would not attempt repair.
Double check that all is secure before using again - and turn off BEFORE opening the door each time.
Posted on Jun 11, 2008
R-9H84B. It just stopped working.Went to use it and nothing , thought it was unplugged. Repair man replaced the 20 amp fuse and it immediately blew. He said it was the transformer.Is it transformer?
It could be the transformer. Is it generating any smoke? They usually burn up because of shorted windings.
If the fuse blew, however, when the door was opened or closed, then you have a bad door switch.
If the unit heats, and the fuse blew after a few minutes, then you could have a weak fuse holder.
Jan 12, 2017 | Microwave Ovens
Opening the door tripped breaker a few times, now microwave will not power on.
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Apr 06, 2015 | GE Monogram ZE2160SF Convection /...
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power went out
Try unplugging the unit and replacing the old fuse with a new equivalent fuse (location varies with the brands). 9 out of 10 times, the fuse is the culprit,
Nov 22, 2008 | Microwave Ovens
The fuse blows when i plug the microwave in with the door closed
first you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
Nov 16, 2008 | Microwave Ovens
H5470 built in microwave
sound like the door monitor switched has blown or shifted out of position if the switches dont operate in tandem when door is opened or closed it will blow the 10 amp fuse and kill the display they will need to be checked by engineer if it is monitor switch they are not expensive to replace.
Apr 01, 2008 | Neff H5470 Microwave Oven
No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
Blowing fuse problems
The door latch switches, and monitor switch assembly needs adjusting. With the door open the two latch switches should be normally open,and the monitor switch closed. Opposite way when door is closed. MAKE sure oven is unplugged before testing
Jun 28, 2007 | Daewoo KOR-860A Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
