Question about Weather King 10AJA2501AH Air Conditioner
Warranty on compressor
I was told that the valves are starting to fail in my compressor. My unit is 10 yrs. old. What kind of warranty if any is on the unit? Model #WAKA-037JAZ
    Novelist:
    Champion:
  • 230 Answers
The actual age of your unit can be determined by the serial number. Based on the age indicated there they can tell you if the warranty is still valid. Your local Rheem/weather king dealer can do this for you. Most compressor warranties are either 5 or 10 years. Good Luck!
Posted on Jul 03, 2008
I have a maytag side by side refrigerator freezer with a Embarco EGY 100 HLP compressor
Probably not. Sounds like compressor would have to be replaced. It's an expensive repair. It would depend on age if unit
Oct 12, 2017 | Maytag Refrigerators
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Have a Kenmore side by side that is not cooling any more. 5 yrs old. sounds like the compressor is trying to kick in, but doesn't tries again every minute or so. Any suggestions?
Good day,
Yes, You have a 5 year warranty on the compressor.
If you are right there, I would call the selling dealer and see what they can do for you. They have a little wiggle room so it's worth the effort.
Your compressor cannot start. There are start components on the body of the compressor that could have failed, or the compressor itself could have itself failed.
You can remove the start components off the body of the compressor and take them to an appliance parts house for testing. Under the cover on the side of the compressor, is a relay, overload protector, and on some models a run capacitor.
The components could have failed on their own, or burned out because the compressor grounded out.
It is safer to have a trained tech check the machine.
He has a starting device that can run the compressor independent of the unit, and see if it warrants replacing start components.
Feb 05, 2010 | Kenmore 52672 / 52674 / 52679 Side by Side...
Worth fixing 9 yr old unit? Told the keypad going bad. Often powered off/on to reset is required. Expensive repair?Complicated? I am quite handy if part swap is an option. I recall hearing a microwave is...
Hi - I really do not like to condemn any machine however microwaves have become very inexpensive - more efficient - quieter and packed with more features than ever before for a reasonable price. If you are handy unplug the unit and remove the front panel (a few screws ) at the keypad to expose the keypad harness, please check the harness connection. It is not uncommon for a keypad to fail. If the keypad still fails I advise purchasing a new machine simply because the parts, shipping etc will likely exceed the pro rated value of your machine. I know it is hard to let go sometimes but in the case of old microwaves it is generally wise. Microwaves can last well over 10 years. The good news is you will be getting a warranty with your new one should you decide to go in that direction. Hope its the harness, Sincerely Brian
Nov 26, 2009 | GE JEM31 Microwave Oven
Blower no cool
Chances are the tech said it was a "capacitor".
That is one of the few (and minor) parts that routinely go bad and would be no suprise with a 17 month old unit. Nearby lightening strikes or power surges can cause them to fail. That is true with all brands.
(the condensor is the entire outdoor unit)
Goodman systems typically come with a 1 year all parts warranty, and a 10 year compressor warranty.
Since your unit is 17 years old the capacitor is not under warranty. (unless you purchased an extended warranty plan of some kind.)
$90 is reasonable compared to the typical going rate for a capacitor replacement and service call.
Aug 25, 2009 | Heating & Cooling
Flashing display and ticking coming from the back
The clicking noise you hear is the compressor trying to start but the overload is tripping that is hooked to the compressor. Either you have a bad start relay which I would replace first or your compressor is locked up. If the unit is under five yrs old but older than January 08 then the compressor not the relay is under warranty. Jan 08 manufactorers have put a one yr warranty on compressors. Its real easy to replace the start components on the compressor. Unplug first then take back panel off. If the compressor is hot more than likely the compressor valves are bad and wont pump which overamps then trips overload. Then resets and tries again. But if compressor is cool then you should be able to replace start relay and compressor should start up. Those relays usually get too hot from dirty coils and/or a bad fan motor by the compressor that blows air across it to keep it cooler. But the cost of new fridges is an incentive to try the relay. Hope this helps.
Jun 10, 2009 | Refrigerators
I bought a Frigidare refrigerator today. Warranty needed?
its really just up to you. I am a service tech in grants pass oregon and i know compressors dont last anymore. Its because in the last 10 years they have switched from r12 freon to 134a. 134a has higher head pressures which make the compressor go out. If the compressor warranty isnt too much money i would do that warranty. You dont really need the others.
Jan 29, 2009 | Frigidaire Refrigerators
Whirlpool refridg side by side
This sounds like the compressor is bad. The clicking sound is the start relay trying to start the compressor and cannot. You stated that it was only four years old. Check the warranty for your frig. Most carry a five year warranty on the compressor.
Nov 10, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Carrier A/C Unit
Be sure that the starting capacitor is good. If the compressor is stuck up the starter power pack may help but sometimes it fail.
Sep 08, 2008 | Carrier 36KCARMS Air Conditioner
Goodman Heat Pump GSH 130601 5 ton unit - Compressor seized
Tell them you want a whole new outside system or a new compressor . Around here, the compressor change out should be around 5--$800.00 and the unit change out , around $400.00! OKLAHOMA.
Aug 02, 2008 | Goodman CLQ36AR49 Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
446 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
