Question about Canon imageCLASS D780 All-In-One Laser Printer
Error 000 looking on the web, seems to be fuser error. so, i ordered a fuser from precision roller. came in today. am looking at this machine (canon imageclass d880) and for the life of me, i can't see how you would change this. looks to be in the center of the machine. i've taken some of the plastic covers off, and it seems to be in the center of the cage. any ideas would be of help. i've built tons of computers and fixed several printers/faxes but haven't come across one this difficult to access..... thanks kevin
Canon imageCLASS D780 has error E0001-000. Any idea what that means?
Posted on Oct 27, 2008
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
HI, This is IRFAN, i have Canon IR 3300 copier machine i got a error e007 000, i know the that is fuser film rotation error, but, i had remove the Fuser unit (FG6-6040-000) from the machine and manually...
If you confirm about film's inside lubrication then cheak out for gear inside fixing drive assembly . open front door , open inner cover then open the drive assembly from the left and cheak the gears.
Aug 25, 2017 | Canon Ir 3300i 3300g 2800i 2800g 2800 2200...
If problem persist contact dealer or service rep turn the main power on e301-0001
This is a fuser error, the fuser replacement for this machine is best done by a technician as there is moderate disassembly involved..
Your local canon warranty agent will be a good place to start.
This same printer engine is used in a few HP printers and multifunctions and the fuser is available from HP as well. Though HP are usually slightly dearer.
If you want to have a go yourself the part number is one of the following, depending on your electrical grid voltage un your part of the world
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 120 Volt
RM1-7576-000
or
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 230 Volt
RM1-7577-000
Oct 26, 2013 | Canon ImageCLASS MF4450
E005 error
The cleaning Web for the fuser has exceeded its acceptable life counter. The web needs replaced and the counter reset in service mode.
Cleaning Roller Part Number- FA3-8908-000
After replacement, be sure to reset the cleaning web counter in service mode under.
COPIER>COUNTER>MISC>FIX-WEB
To access service mode press the asterisk ( * ) the number 2 and 8 at the same time, then the asterisk ( * ) again.
Oct 09, 2013 | Canon imageRUNNER 400S Copier
My mechine display an error e002.
Error # 0002 indicates "Fuser temperature not rising at correct pace. Same possibilities as E000"
Error #000 refer to a number of possibilities "Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller
Replace the Fuser Roller also known as the Pressure Roller or Upper Roller to resolve your problem.
Mar 08, 2011 | Canon NP 6035 Copier
Error code007
This is a fuser error code meaning that the fixing film in the fuser is not rotating and is most likey damaged. You will need to replace the fixing film assembly ( FG6-6039-000). The other parts you may need, if damaged are FG6-5709-000 , Cleaning Roller, Fixing and FB5-4942-000 Pressure Roller. First of all try resetting the code. Additional function key, then 2 & 8 keys at the same time and then the additional function key again. Press Copier, Function ( at top ), CLEAR, ERR, then OK. Power down copier and power back up. It may work temporarily but the fuser assy needs to be looked at.
If the error comes back, reset the error once again and leave copier turned off and better yet unplugged.
Open the front door, lower left door and remove the screw from the cable that holds the door up ( black screw that is in the door ), then lower door more until you can unplug the connector and carefully lower further to remove door completely form the copier.
You will see a black cover on the left side rear - unscrew and remove it. Then unplug the three connectors underneath it.. Remove the black paper guide cover over the fuser assy by removing the brass colored screw on the right. Lower it carefully and remember to see how it goes back into position. Remove the two screws that secure the fuser and remove the fuser. Sometimes angling the fuser from the rear first helps in removal.
You should be able to see how to separate the fuser assy by removing the two springs and carefully looking and loosing the wires on the left side. Determine what things need to be replaced and reverse proceedure for reinstallation.
Dec 08, 2010 | Canon imageRUNNER 2200
Error problem e013 view machine
If I rember correctly a E013 error code means that there is something causing a drag in the copier. Do you hear a clicking sound before it codes out? I would look in the fuser unit and see if the cleaning web is wraped around the upper fuser roller or if the Lower fuser roller is cut and causing the fuser not to turn. If that turns OK, I'm almost sure you may have a packet waste toner aurger or waste toner tube is cluged. If that is the case you will have a packet AP kit... Good Luck
Jul 10, 2010 | Canon NP 6545 Copier
Fuser film has split so looking for part number of fuser film or fuser assy of canon L100 fax machine
FM2-3967-000 FIXING ***'Y FOR 120V, and
FM2-3968-000 FIXING ***'Y FOR 230V.
Best way is to replace whole unit, because of pressure, bushings,...
Jun 04, 2010 | Canon Office Equipment & Supplies
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
Canon imageCLASS D780 All-In-One Laser Printer Logo
139 people viewed this question
old marine
old marine
