Question about AT&T Blackberry Curve 8300 Smartphone
Bluetooth Pairing Blackberry 8310 to Jaguar XK 2007
I recently purchased a Blackberry Curve 8310 and have been trying to pair it to my Jaguar XK 2007. Bluetooth is enabled on the curve. The car searches and searches for the phone but does not find it. The phone discovers the car and asks for the numeric code. The car is suppose to generate a random # on its touch screen that I then am suppose to enter into phone but it never does. Is there something I need to do different with security etc? encryption is off, etc...is there a generic code I can enter on the phone that then the car will accept and pair?
  • 10 more comments
  • Anonymous Jun 22, 2008
    is there a solution? I have the same problem!
  • Anonymous Jul 01, 2008
    same car same phone and 0000 doesn't work
  • Anonymous Jul 03, 2008
    same problem... and I tried punching in 0000 and 1234 to see if that would work. They didn't. Now I'm going to punch my dealer.
  • Anonymous Aug 10, 2008
    Yup same problem with the 2008 xk
  • Anonymous Aug 22, 2008
    exactly the same pb with blackberry 8700/bluetooth and Jaguar XK/telephone: what to do?
  • jmcall Aug 30, 2008
    same problem..I downloaded the blackberry fix....no luck in pairing
  • parangchick Nov 18, 2008
    I am having the same problem with the blackberry 8300 and the 09 Altima. It paired perfectly and received a call at the dealer. I turned off the car and the phone is still paired but the systme says no phoe found. Help -Verizon certainly was not helpful and the dealer was baffled since it paired and worked perfectly with the chocolate phone.
  • Anonymous Dec 01, 2008
    I have Blackberry Storm 9500 that pairs with Jag 2007 XK and able to make calls but fails when I try to transfer the Blackberry contacts to handsfree device on Jag!
  • joc1362 Dec 06, 2008
    Same problem with 2009 Nissan Maxima. Paired for a while, won't now.  Car pairs fine with wife's mobile, but not Blackberry Curve now after it did for months.
  • lanman27 Mar 05, 2009
    My Blacberry 8330 stopped pairing in my 2009 maxima - worked for a few months now stopped - anyone have ideas?
  • Anonymous Mar 08, 2009
    i cont active  bluetooth to blakberry
  • winger00 May 03, 2009
    Same problem with the blackberry...has anyone found a solution?
    Problem Solver:
I think you need to punch in (0000)
Posted on Jun 14, 2008
    Problem Solver:
  • 3 Answers
I haven't tried this with a Blackberry, but I just fitted a phone module and Bluetooth module to my Jaguar and it took me a while to figure out how to pair my HTC Touch HD.
Here's what I did. I have SatNav so it may be different without.
When you turn on the ignition, in phone mode, the display says "Discover Me" under the signal strength display, right side of screen.
Set your phone to search for a bluetooth device. It should discover "Jaguar". Select this.
It should ask for a passcode. Type in 1313
The phone should now pair.
The first time I tried it I entered no code and then "done" on the phone which said it was connected but the Jag didn't. Then the Jag bluetooth asked the phone for permission to access it and I said Yes on the phone. It then asked for a passcode again which I would imagine requires 1313. I didn't know what the code was then though so I'm not certain which is the correct way to do it but the second way might be better if you experience phone book transfer problems. I had to Google it.
David
Posted on Apr 18, 2009
I have a Blackberry Curve 8320. I purchased a Motorola Universal Bluetooth Headset H620 that is supposed to be Blackberry compatable. I am unable to get my phone and bluetooth paired. What do I need to...
It may be the pairing code that you are using. Usually it is 123, 0000, 1111, 1234, or some other variation.
Make sure, also, that you are in pairing mode with the headset. If you can scan via bluetooth and detect the device, then it should be ready to pair.
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry Curve 8310 won't pair!
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 26, 2009 | Blueant Z9i Bluetooth Headset
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Bluetooth
Your bluetooth needs to be in pairing mode. Depending on what model bluetooth there are several methods to put it in pairing mode. the most common is pushing and holding the main button until a light changes color.
Dec 02, 2008 | RIM BlackBerry 8800 Smartphone
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Parrot 3100 pairing with blackberry 8310
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
Apr 19, 2008 | Lands Phones
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
AT&T Blackberry Curve 8300 Smartphone Logo
841 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
castletech
castletech
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
