Question about RIM BlackBerry Pearl 8100
Targus wireless mouse model:amw05usx. computer says replace item doesnt recognize. worked great before this message
  • 1 more comment
  • Anonymous Sep 07, 2008
    I don't get that message, my computer just doesn't recognize the mouse at all. I thought that maybe the X afrter the model number is for a MAC?
  • Anonymous Jan 06, 2009
    I have the same issue. Upon opening up the receiver I found that all but one of the four wires are broken between the USB and the receiver body, right where the two pivot. I am looking now to see if I can fix it.
  • dde_alba Apr 15, 2009
    I have the same problem, for the first several months my mouse and receiver (model #: AMW05USX) both worked fine. But now, nothing. I replaced the battery in the mouse and the light shines a bright red, but still nothing.
**** it hehe
Posted on Jul 05, 2008
I have a targus wireless mouse MODEL:AMW1603EU the reciver light does not come on and the mouse light doesnt go of nor does it work.
Did you ensure the ON/OFF Switch is set to ON? Did you also try replacing the batteries, then pressing the connect button on the receiver followed by the connect button on the bottom of the mouse?
Jan 14, 2010 | Targus Wireless Optical Notebook Mouse...
Targus mouse not working
I checked the Targus website (http://www.targus.com/us/default.asp) for any other useful information. Use the "support" option at the website for a good troubleshooting guide for your particular mouse. Is this a new mouse? The mouse you have uses the native windows drivers and should be auto-recognized by XP. Have you kept your XP updates current? My concern is why XP could not install the software drivers needed(You would have gotten some type of an error message). Check the "details" link shown with the error message.That should point you in the right direction---rick
Sep 10, 2009 | Targus Mini Kaleidoscope (AMU0503US) Mouse
Targus mouse not recognized and malfunctioned when plugged in....
install teh software first and then connect the mouse. It shall help
Sep 03, 2009 | Microsoft Wireless Notebook Optical Mouse...
2 xTargus wireless mouse- both seem to be working on same freque
there is a range limit and if u move far enough apart they will stop interfering, or use differant mouse on one computer and kep other mouse for replacement
Jul 07, 2009 | Targus ACP50US Docking Station
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Mar 11, 2009 | Targus PAWM001U Mouse
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Aug 24, 2008 | Targus Wireless Optical Notebook Mouse...
Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Feb 25, 2008 | Targus AMW15US
RIM BlackBerry  Pearl  8100 Logo
1,282 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
