Question about Jabra JX10 Bluetooth Headset Headset
Jx 10 bluetooth linage code
What is the code to enter into the phone to link the headset?
The code for the JX10 is '0000' (four zero's)
Regards
Peter
Posted on Jan 27, 2009
Peltor MT53H7AWS2 Bluetooth Headset pairing instructions
• Establish the Bluetooth link between the headset and another Bluetooth device by pressing the raise volume (+) and lower volume (-) buttons simultaneously for at least two seconds. Note that the headset must be switched off while you do this!
Some models of mobile phone require a pin
code in order for the mobile phone to identify the
headset. If this is required, enter four zeroes (0000).
This applies to all Peltor WS headsets and cannot be
changed by the user.
Nov 07, 2012 | Peltor MT53H7AWS2 Bluetooth Headset
I HAVE A T303 TRYING TO LINK A AKONA EAR PIECE FOR THE FIRST TIME NO NSTRUTONS
  1. Turn the Bluetooth on and hold down the button until the light is solid.
  2. Put the phone in discovery mode or search for a Bluetooth device.
  3. Pair the Bluetooth to the phone and enter the pass code "0000" (0000 is the default pass code)
May 31, 2011 | LG SGBS00000303 Bluetooth(tm) HBM-500...
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
Phone does not detect headset
Put your headset in pairing mode first. Turn it off. Then, press and hold the MFB for some 8 seconds, until the indicator light is steady blue. Then, make your phone's bluetooth application search for new devices. Your headset should appear on the phone screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash rapidly 10 times, and enter the stand-by mode (light flashing every 3 seconds). The pairing procedure should be done only once. After any two devices are paired, just by bringing them within 10-feet from each other should suffice to have the bluetooth link done. Otherwise, a simple press on the MFB should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to pair your headset with your phone.
Regards, Carlos
May 28, 2010 | Samsung WEP200 Headset
My Blackberry is asking for a code to pair with my H700C headset?
Enter the code 10 times false, then your phone will reset himself and let create new one.
Feb 03, 2010 | Motorola Mobility Bluetooth...
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Oct 08, 2009 | Motorola Mobility H500 Headset
How do i pair it wiyh my phone?
Try these:
  1. Turn your phone's bluetooth on. Maku sure your phone is discoverable.
  2. Press and hold call button on bluetooth headset until prompt appears on phone telling you to enter pairing code.
  3. Enter 0000 as default pairing code.
Sep 04, 2009 | Cardo scala 700LX Bluetooth Headset
GE bluetooth connectivity problems help!?
Code is 0000. Enter this in your phone when requested in blue tooth settings. If your phone already a bluetooth paired before, delete this entry first. Make sure there is no other sell ohone with in 50 feet when pairing and this should solve your problem. Tech Malick
Jul 29, 2007 | GE Bluetooth In-ear Headset Wireless...
Jabra JX10 Bluetooth Headset Headset Logo
73 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
