Question about LG WM2688HWM TROMM SteamWasher
Mildew type stinch and possible related skin rash
I have the LG Tromm and after a few months the mildew tyrp stinch and rash that is possibly related. What ever happened with your situation? Thanks again
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Try using www.affresh.com, run your tub clean program with it. Try a different brand of HE detergent and cut back on your fabric. softener. It could be the detergent you are allergic to.
Sgt 48
Posted on Jun 14, 2008
LG WM2050C* MILDEW & MUST SMELL
Did you check to see if it has a filter to it, If there is one that would most likely be the problem
Dec 18, 2015 | LG Washing Machines
I have noticed that a rash is starting on my face, what could be the reason?
Rashes can be caused by allergic reactions to the skin or the shaving products you are using. If you believe this to be the case, try unscented products or products designed specifically for sensitive skin.
Feb 06, 2013 | Health & Beauty
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
Flaky dry skin in the areas that product was used is it normal? I am I suppose to peal next? (glolightning serum)
glotherapeutics gloLightening Serum use to gradually help fades skin discolorations, pigments, spots, blotches or areas with freckles, age and liver spots.It seam this product is not good for your skin.In their use manual say that if you used it for 3 months and is no result to not use it anymore.Yes it is used on the areas you need but if your skin is flaky than is no good for your skin, and no it is not quite necessary to peal .
Jun 14, 2011 | Gloprofessional glotherapeutics...
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
