Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Mower won't start
The mower stopped running when I attempted to push it through thick grass. Is the motor dead?
    Champion:
  • 313 Answers
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Posted on Jun 11, 2008
Procedure for adjusting valves on series 100 lawn mower
if you think it is a valve problem briggs and stratton website has a page that gives all the specs. for intake and exhaust vale setting. you will need to know your engine size and model number.
May 29, 2016 | Garden
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
Blade slows down when grass gets thick
The reason the blade slows down when the grass gets thick is simply because the mechanism operating the blade is weak and cannot move fast when on thick grass.
I suggest you troubleshoot the mower. After that, the blade should work fine when the grass gets thick.
Also, some mowers normally gets slow when grass gets thick, so after troubleshooting, if the mower does the same, then you already know it has to be slow when trying to cut thick grasses.
Take care
Sep 09, 2010 | Toro Personal Pace CARB Walk Power Mower
The mower just stopped dead.
clean and tighten all connections from the battery to the starter and selenoid connections too
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My rider stopped in high grass, would not start.
first must by the connection bettw.battery and starter.second mesure short cut of the starter .try cu see if you have the seal battery or not.in this case try to see if there is mixture water + acid(enough) on it.other solution -you have broken battery charger relly.
Sep 11, 2009 | Garden
Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
410 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
