Question about Apex Digital PF3230 32" TV
No Power Apex PF3230 - 32" Digital - No power, tried changing outlets. Does it have a fuse?
  • 1 more comment
  • wfsmalt56 Jun 13, 2008
    I replaced the fuse only to have it blow again as soon as I turned it on. I think that there is a short in the power supply circuit?
    There is no blinking. The fuse looks like it exploded inside. The new one I put in did the same. The TV is plugged directly into the wall.
    I replaced the fuse with another but it blew immediatlely, looks like it exploded insdie so does that mean there is a short? Where do I go from here?
    Genius:
  • 2,028 Answers
Yes, this model does have an internal, high voltage AC inline fuse.
Posted on Jun 13, 2008
  • 3,037 Answers
There are many fuses within the unit. Is there anything at all that may suggest what happened? Any blinking or noises when you try to turn it on?
  • Benjamin Patri
    Benjamin Patri Jun 13, 2008
    Most likely that is the problem, how do you have it plugged in? With a surge protector or directly into the wall?
  • Benjamin Patri
    Something in the power supply is mostly causing this, use the following link to narrow it down better by testing components with an ohm meter. I think that you should probably just replace the power supply but test everything that is said to be tested in the following link if you are able. Let me know if you have any questions while doing this.
    http://www.repairfaq.org/samnew/tvfaq/tv...
Apex LE2414 won't stay on
It is likely that there is a problem with the internal power supply.
Dec 31, 2013 | Apex Digital Apex 24 in. LED 1080P 60Hz...
Apex Gt2715 wont turn on
that was mean their is a problem either in the power supply section or at the main board. which need a proper trouble shooting and repair. which can be hand held by a trained tv repairman. just let me know if you will be the one to do the repair so i can give further solution.
Dec 07, 2012 | Apex Digital GT2715 27" TV
Won't power on
Check your power outlet for any loose contacts and ensure there is power. Try connecting the TV to a different power outlet.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | Apex Digital Apex 32 Class 720p 60hz LCD...
My apex will not power on?
Please if power light does not come on follow power cord inside (set unplugged) to the main fuse that the cord goes directly to.
Apr 09, 2012 | Apex Digital Televison & Video
Won't turn on/no power. Worked fine until i turned it off as usual, went to turn it on, no power either from "ON" button or remote. wall outlet works fine, tried it in other outlets, no luck.
Well, I used to be an authorized Apex repair center and absolutly could not get a part for a tv. You may just have a bad H.O.T. ( horizontal ouput transistor) which is what I needed. I don't even know if they are still in business. Good luck.
Oct 23, 2009 | Apex Digital AT2402 24" TV
TV loses power
Sounds like it maybe a heating up issue? Do you have it in an enclosed space with very little ventilation? These models don't like heat.
Sep 09, 2009 | Apex Digital AVL3076 30 in. HD-Ready LCD...
AVL 2026...
yes, there is a small circut board mounted fuse on the main board. Its looks like a resistor but its glass and has a filament inside.
Apr 18, 2008 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Apex GB43HD10 REAR PROJECTION
You did better than me. 1 year one week.
Aug 21, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex Digital PF3230 32" TV Logo
190 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
