Back to:
Tags:
Jenn-Air JCD2389G Side by Side Refrigerator
Rust on Jenn Air Refrigerator Door at Water... (by 2 users)
posted by The old COL on Jun 11, 2008
Hi, there. We have a relatively new (6 years old) Jenn Air side-by-side refrigerator/freezer. Rust has started forming at the water dispenser below the overflow collection "plate". A long vertical "snake like" streak of rust is going alway the down the door.
Any suggestions on how to remove the rust from the water dispenser and fix the rust streak down the door?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by spiroa, posted on Oct 06, 2008
I have the same problem but with a Stainless Steel fridge. Any way to remove the rust from the Stainless Steel?
Best Solution
posted on Jun 11, 2008
Helpful (85)
Richie_asg1
Rank:Guru Guru
Rating: 86%, 183 votes
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rust on Jenn Air Refrigerator Door at Water Dispenser:
I don't want to Accept this solution
Solution #2
posted on Jul 03, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a white side by side refrigerator that started forming small streaks of rust all over the refrigerator door. It is still in good running condition with almost spotless interior except for the exterior problem I stated. What shall I do to fix it?
Thank You!
Can you Help with these Refrigerators problems?
My side by side is really hot to the touch between the...
My Jenn Air refrig model # JCD2389GES is not cooling on...
It appears that there is a latch that doesn't catch...
the refridgerator has rotating handles to raise and lower...
my jenn air refrigrator stoped mamikng ice
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
