Samsung j1453s washing machine keeps coming up with code 4e check everything for blockages and theres loads of water pressure any ideas thanks
  • 5 more comments
  • brokenmachin Jul 06, 2008
    we have exactly the same problem, also checked everything but it still wont work. Washing machine wont wash a load and wont empty properly.
  • Bumpit Jul 10, 2008
    Have the same problem - however it now will fill and fill till it stop it , however it will emtpy
  • linzi2206 Jul 23, 2008
    same thing aswell, 4e keeps coming up, wont wash a load,
  • sazzle Aug 26, 2008
    argh - same problem here! Will check the white cable as suggested tomorrow and let you know! Hope it works!
  • Simoncito73 Mar 24, 2009
    hello guys, does anyone know how to block the washing machine? i have a samsung J845 in a shared laundry, but the machine is mine and i don't want to share it or let other people use it as they have other machines there to wash their clothes.
  • chinnihere May 11, 2010
    hi, thanks a lot...actually i was thinking of buying a new washing machine but this tip worked and it saved me atleast 250 pounds.
  • peteroctavia May 11, 2010
    paid 30 quid to fix the problem 4e, which easily could be done by anyone. the fault is the tube to the pressure switch, take the top off the washing machine, and at the front you will find a white block attached by a screw to the top of the washing machine at the front this is attached to a plastic tube, which in my case had split, snip the end off, and attach back to the white block, this should now work. hope this has helped someone, as it would of helped me.
    I had the exact same problem.Your fixya solution as above was excellant. And it saved me the call out fee and the repair cost. So that was ace. Thank you very much. Samsung must get to grips with this problem.
  • 3 Answers
Wow - nice one it fully works! We got the wrong white box first though - then i checked the small one and the underside of the pipe had a split inso we snipped it off and it is now working a dream! Thanks so much for the tip - I can confirm it works!
Posted on Aug 27, 2008
Worked for me too. Took half an hour to fix, with a couple of screwdrivers, some scissors and a pair of pliers to grip the clamp. Easy! Just make sure you've unplugged the machine and turned the water off before you start moving it and opening it up.
Posted on Jul 25, 2009
Posted on Dec 15, 2008
This solution works!!! I am a women with no clue and managed to find the tube which is a bit tricky at first but it is on the front right side. The underside of the pipe had split and just needed cutting off. Thanks again so much for this great money saving tip.
Posted on Sep 27, 2010
Paid 30 quid to fix the problem 4e, which easily could be done by anyone. the fault is the tube to the pressure switch, take the top off the washing machine, and at the front you will find a white block attached by a screw to the top of the washing machine at the front this is attached to a plastic tube, which in my case had split, snip the end off, and attach back to the white block, this should now work. hope this has helped someone, as it would of helped me.
Posted on Jul 29, 2008
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
My washing machine comes up with error code 4e i have changed the solenoid valve and cleared any possible blockage water is flowing in to the machine but still getting the same error code if i chose the...
Your machine has a fault with the water level contoller switch - pressure switch that activates when water reaches the level set . So check the water level controller and test. If not the fault can be with the program controller unit.
Please check this link for parts identification.
http://www.espares.co.uk/advice/washing-machines/a/7/40/identifying-washing-machine-parts.html
Sep 17, 2011 | Samsung Washing Machines
2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
4E error....samsung J845
Aug 23, 2009 | Samsung WF203ANW Front Load Washer
4E showing on Samsung Washing Machine
Apr 06, 2009 | Samsung WF337AAL Front Load Washer
My samsung washing machiene keeps coming up with the error 4e. what does this mean?
Mar 15, 2009 | Samsung WF337AA Front Load Washer
4e code
I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
Hope this helps.
Dec 26, 2008 | Samsung WF337AA Front Load Washer
Samsung Washing machine fault
The manual says Mke sure the soucre water faucet it turned on. Check the water pressure. turn off water and unscrew the hose from the back of the washing machine. it says to pull out the nesh filter from the end of the hose and ricse it under water until clean with a pair of pliers.also clean the inside and outside of the threaded connector. push the filter back into place, screw the hose back onto the washing maching. turn on the faucet and maike sure the connections are watertight.
May 15, 2008 | Samsung WF203ANW Front Load Washer
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Jan 16, 2008 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
902 people viewed this question
Top Washing Machines Experts
