Question about Saeco Royal Professional Espresso Machine
No coffee being dispensed
We've a Royal Pro which is the lifeline of our office.
Recently it stopped delivering coffee.
So I cleaned out the grinder as per instructions and did a descale.
The machine ground coffee and the brew-group did it's stuff (removed dregedrawer and engaged the interlock). However, no coffee or coffee grounds in the dredgedrawer.
I'm assuming that the doser is not opening on command. Is it mechanically operated?
  • 40 Answers
I had a similar problem- you need to re-adjust your grinder setting again. It took me several tries to re-adjust and finally it is back working.
Posted on Jun 19, 2008
My Saeco Xsmall stops before brewing the coffee
1- The grind fineness setting is too fine. Pump is not able to pump through the compacted coffee grounds.
2- The machine is not descaled. The Calcium deposits in the hydraulic system have reduced the pump pressure. The partially clogged water passages can generate a back pressure to reduce pumping pressure. Was the machine descaled in the past two or three moths? If yes, what was the descaling product used?
3- The pump may be air locked and not able to pump water.
4- Oily beans may have been used. Oily beans are poison for the all fully automatic espresso machines. This clogs the grinding chamber or the grinder outlet. This model is made in Romania made in 2006 or after. This machine has a Ceramic Burr grinder 2006 which is a huge problem to clean adjust beans quantity per shot of espresso etc. etc. Occasionally it will dump dry coffee grounds when the quantity of beans powder is insufficient.
Based on the above details, you can figure out what is wrong and fix it. See the exploded parts diagram included, for help. Services Unlimited Inc Parts Guru Since 1988
Dec 29, 2016 | Saeco Coffee Makers & Espresso Machines
Saeco Grinder problem
The machine possibly out of carbon lead, which is use for electrical contact to the machine.
Mar 02, 2008 | Saeco Royal Professional Espresso Machine
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Why my saeco royal not grinding?
hi,
pls try to describe what are the symptoms.
Grinder might be dead, or the doser switch may say that there's no need for grinding because it feels there is enough ground coffee.
I would clean the grinder completely, clean the doser from all ground coffee and give it a try and let me know.
Hope that helps.
M.
Apr 11, 2016 | Saeco Royal Professional Espresso Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Coffee coming out too slowly
Hi have you changed your coffee or your grind recently?
if the grind is to fine then the flow will be reduced or stops altogether.
has the machine had a de-scale recently ?
If it needs a clean this could block up the machine.
Oct 21, 2013 | Saeco Royal Cappuccino Espresso Machine
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
Our Saeco Vienna Deluxe will not stop grinding. Any ideas?
Hi
3 things
1. Grind is too fine. Move to a very coarse grind, say 16.
2. Move the small knob to the - side and try again.
3. If that didn't work your going to have to clean you grinder.
Need instructions? email me.
Jan 05, 2010 | Saeco Vienna De Luxe Espresso Machine
Bean Grinder
Hard to say when i´m not have the machine in front of me, i think it can be the printed circuit card.
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
126 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
